Can't argue if you are happy with -BJ
mau47
Northeast
23 F150 502A Powerboost FX4
I was able to get everything updated except for the SCCM. Based on the error it seems like something on Fords side. Since it's just the SCCM I'm not too worried about it but wasn't sure if theres a way to correct the problem. The error I am getting is:
Procedure Unsuccesful - com.sun.xml.internal.ws.fault.ServerSOAPFaultException: Client received SOAP Fault from server: No matching procedure was found for idG2421626 and encryptionAlg security_01 Please see the server log to find more detail regarding exact cause of the failure.
Big Dog Daddy
New Jersey
I read recently somewhere that's there's a known issue with the current SCCM update and Ford is working on a new software update to correct the issue.
mau47
Northeast
I thought I remembered reading that as well but the only thing I could find was a DTC that gets thrown after the update is installed from November, but could be related if maybe they pulled the update?
SSM 52078 2021-2023 F-150 - DTC U023A:08 After Steering Column Control
Module (SCCM) Reprogramming
Some 2021-2023 F-150 vehicles may exhibit DTC U023A:08 after reprogramming the SCCM. Do not replace
or reprogram the SCCM, image processing module A (IPMA) or their components for this condition at this time.
This DTC does not alert the customer, will not affect vehicle durability and no additional diagnosis or service is
required for this condition at this time. Engineering is currently working on a solution for this condition that will
reprogram the IPMA and is expected in late December 2023. Monitor OASIS for additional information.
PSA for the people with FDRS applying updates: Yesterday, a dealer was applying updates to a Mach E and when they got to the IPMA, the update wouldn't take and it bricked the module. Today, a member on the Lightning forum reported the dealer tried to update his truck bricked a module. When I checked it, it was the IPMA, too. I am not sure if this is an issue that only affects EV's, but two different vehicles in two days is too much coincidence.
I wonder if they updated the IPMA software on FDRS to an even newer version and that isn't compatible? ?
Fordphanatic
Boothwyn
2021 Platinum F150
Union Carpenter
We are going to find out right now if it's bricking modules on gas trucks. I'm 2 hrs into the ipma update right now on my neighbors truck. Fingers crossed. It's been configuring the module forever. I'm starting to get nervous.
Big Dog Daddy
New Jersey
Best wishes, I want that to work for you! :) keep us posted.
Fordphanatic
Boothwyn
2021 Platinum F150
Union Carpenter
JEB
2021 F150 Lariat PB 502a
I’m not sure how new the IPMA update for the MME and Lightning is, but the one you are applying now came out about a month ago. A lot of people have applied it without issue. You should be fine.
Tell them thishappened to that guy I helped yesterday .. and the IPMA is recoverable.
Oh, I'm sure you can recover it. These guys are at the mercy of the dealer, though.
Fordphanatic
Boothwyn
2021 Platinum F150
Union Carpenter
