Testing an Aux batt solution...
Chuck Woolery
Wisconsin
2023 F150 XLT Powerboost, 2014 Mustang GT/CS
13.3 right after I shut it off. 15 when running.
Mine does the same thing. Going to check the BCM connections tonight now to see if there's an improvement. Glad I checked back on this thread.
wolfman1
Ryan
Charleston, SC
2022 F150 Lariat PB 502A
I just noticed that after getting my X2 battery installed. My resting voltage was 12.4 with the OEM auxiliary battery (immediately after turning the ignition off).
Only modification was a small amount of trimming to the positive terminal cover to give some clearance for the cable. I haven’t touched the top cover yet since I’m not sure where my final mounting location will be.
4awg cables hooked up and slid the battery into the adjacent compartment and now my resting voltage shows 13.2 after turning everything off. I’m impressed so far.
I’ll keep an eye on it and report back after I get some more time with this setup.
My 22 PB has already had one OEM battery replaced after constantly going into deep sleep mode, despite being charged/BMS reset. That was just over a year ago, and the new OEM H7 replacement the dealer put in is starting to exhibit all the same signs. Should I swap in a new, better H7 battery before adding a new LiFePO4 to keep everything operational long-term?
FaaWrenchBndr
Denver, IN
‘24 XLT Powerboost
Napa has a very solid choice for a H7
Jmitchelltfo
Jeremy
Ozarks
2021 King Ranch PB
Range Ops
You’re the only one that can answer that. My stock battery is working fine, but if your new one doesn’t test out, Napa or Walmart has a great replacement for it.
As far as the LFP (parallel or replacing the OEM battery) that is totally up to you. You need to have a small amount of DIY skill to complete that task though.
It was totally worth it for me so far. With a 10-year free replacement, I have a decent amount of confidence that the build quality is solid on the X2 LFP.......but I will continue to keep an eye on my voltage monitor to watch for signs of early degradation.
I still have the original factory underhood battery in my 2022 (April 2022 build) Powerboost. The LFP Auxiliary seems to have given it some new life? ?
Note that I have also never "reset" the BMS to date. Although the truck has had BMS updates over the ~3 years it's been in service.
RyanStroeder
Calgary, Alberta, Canada
2021 F-150 Powerboost - Leadfoot
that's impressive indeed. do you put the truck on a battery tender when not driving for a day or two?
I used to. I had to because the voltage would drop below 12.3 and I used that as my threshold for intervening BEFORE the AGM would experience the kind of harm an AGM would if it was depleted too much.
But I don't think that's going to be necessary any more. Or it doesn't look like it is going to be since after 8 days of sitting the voltage hasn't dropped measurably at all.
Resting voltage on January 19th, the last time truck was driven
Ford F-150 Testing an Aux batt solution... Screenshot_20250129_142547_Battery Monitor
January 27th. 8 days later sitting in the barn. That's simply amazing.
Ford F-150 Testing an Aux batt solution... Screenshot_20250129_142616_Battery Monitor
Thanks goes to the mad scientist HammaMan.
It's been 2 years since I'd put the first LFP into my truck. It just works
Spiffy
Usa
2022 platinum powerboost
Been a week now. After cleaning my connector on the bcm I haven't had any more battery saver nags..
Ford F-150 Testing an Aux batt solution... Screenshot_20250129-185234
That's a nice 12.9/12.8 resting voltage for Powerboost AGMs.
Spiffy
Usa
Ya om confident that issue is gone. Now on to my next problem. Ipma won't calibrate.
wolfman1
Ryan
Charleston, SC
I'm thinking of doing the same setup as you shared above. Out of curiosity, how long did your 4 AWG battery cables have to be?
Jmitchelltfo
Jeremy
Ozarks
2021 King Ranch PB
Range Ops
I built some that were approximately 18” long, but you could probably just buy some battery cables at Walmart a local Napa.
wolfman1
Ryan
Charleston, SC
Do you happen to remember what size lug opening you needed? I want to make sure the cable I get fits the terminals properly.
Jmitchelltfo
Jeremy
Ozarks
2021 King Ranch PB
Range Ops
Somewhere around 1/4” but I just used stuff I had in my garage, so I just remember that it fit 4awg.
