First Truck - Snow Driving Experience Typical?
Jerome10
North Idaho
First truck I've ever owned. Been driving in snow since day 1 with my license so that is nothing new to me for.... too long a time now. But I've always had sedans until now.
Often don't need to venture out much when the roads are snow covered but I did this past weekend and had an "incident" that actually spooked me a bit and I am very very hard to spook even in the snow.
On the expressway, traffic was doing approx 40-45mph. No issues with corners or on ramp acceleration (windy area through mountains). I am cautious and felt that that speed seemed about right. Did have folks passing me maybe 10mph faster.
When time for my exit, I gently squeezed on the brakes well in advance of my exit (ramps tend to be slippery) and was very shocked when the rear end got very squirrely on me. This was a straight brake, no corner or anything, just trying to slow down. ABS started activating in the rear immediately while I got very nervous about the rear end coming around and spinning out. Rear end shimmying side to side. Extremely light brake pedal pressure.
What shocked me so much is that all curves were negotiated prior to the braking with zero issue. Acceleration zero issue. But the braking, which to me is usually zero issue other than making sure you have enough stopping distance, was one of the few times in my life I felt like a car might rotate on me and spin out. The front end seemed to still have traction while the rear clearly did not.
I'm wondering if this is a "problem" in general with trucks. I was well aware of the issues getting moving from a stop because of the light rear end and RWD. That's OK. Either pop in 4x4 or just take my time (I've had a couple RWD BMWs too, so not unfamiliar with that feeling). I also know that if I felt that spooked I was probably going too fast for conditions or the road just at that particular area had a little frost on it or something. That is 100% my responsibility.
But is this normal that during straight braking like that that you can shift so much weight forward that even a slight loss of traction in the rear can quickly make that back end start swaying around on you? I was rather surprised that the truck didn't just engage ABS and track straight, no side-to-side swaying in the rear, like all my sedans have done when I lose some traction during braking. I've never had a back end feel like it was going to come around on me that easily and with such a light brake pedal press. I expected 4 wheel ABS and straight tracking.
I generally have put full winter tires on my sedans. Since I don't generally have to always drive in snow I skipped for the truck but I am now HIGHLY considering it again. I know that will absolutely help.
But is that rear end "action" during braking a thing with pickups generally in slippery conditions? Or did I just happen to hit the perfect bad condition at exactly the time I was hitting the brakes and just a bad situation that isn't really any fault of the truck?
Trying to understand better what I can expect driving a pickup in winter conditions vs a sedan.
As an aside, had an old Corolla before the F150. Other than the FWD and very deep snow (the only time I could get myself stuck), I hate to say it but the Corolla I've found vastly vastly better in winter driving than the truck. Thing was a tank, always knew what the car was doing, very maneuverable, very stable, and it didn't have ABS or stability control. I had FUN with that car in the snow. Just couldn't stop it. I'd hoped a truck might be even better but other than not worrying about deep snow thanks to 4x4 and feeling much safer in the event of a crash... I'd take the Corolla on winter tires every time, hate to say. Truck just seems much less stable and more prone to swing that back end on me.
My 2ND Ford
Ny
But is that rear end "action" during braking a thing with pickups generally? Or did I just happen to hit the perfect bad condition at exactly the time I was hitting the brakes and just a bad situation that isn't really any fault of the truck?
As an aside, had an old Corolla before the F150. Other than the FWD and very deep snow (the only time I could get myself stuck), I hate to say it but the Corolla I've found vastly vastly better in winter driving than the truck. Thing was a tank, always knew what the car was doing, very maneuverable, very stable. I'd hoped a truck might be even better but other than not worrying about deep snow thanks to 4x4 and feeling much safer in the event of a crash... I'd take the Corolla on winter tires every time, hate to say.
Weight transfer, light rear end, no snow tires, road conditions, any number of reasons. Good snow tires, a few hundred pounds of sand bags over the rear axle and some means to keep them there will help. Yes, pickup trucks can get squirrelly in bad weather, its the nature of the beast.
Jerome10
North Idaho
Yeah ok. Maybe I need to look into the sandbags thing. Always seemed silly to haul all that weight around but if its safer...
My truck is 4WD.
jakearb
Jake
2025 F-150 XL Powerboost
Sales Engineer
Nature of the beast for a truck on certain occasions! Has really only happened to me when I forget to turn on 4WD. I've always gone to tirerack.com, picked A/T or H/T category, sort by winter performance, then pick one of the top ones. I doubt you'd need full winter tires in Idaho, I know I don't in Colorado. I even live at 9,000' elevation. I did notice a big difference when I got new tires vs. the ones that come with the truck. The stock tires on most vehicles seem to be lower end.
Jerome10
North Idaho
I am in an area (CDA) where its very on the edge with full-winter tires. I live a little outside of town where many winters can remain snow and ice packed for weeks at a time. Also skiing and 1-2 mountain passes just east of here that get packed even if in-town is fine. And then other winters like this one where you get almost no snow or get thaws in between and the roads are generally clear after a storm is over. Its tough. If I lived in town I'd probably skip them. But when you have them and actually use them, they're really amazing the confidence they provide. Tried a high-rated all season on the Corolla a couple years. They were pretty decent. Then sprung for Conti VikingContact7 (top rated up there with Blizzak and Michelin X-Ice) and truly loved those full winter tires.
I suspect the Goodyears that came on the truck are also a problem here too. Good point.
I was in 2WD at the time. Didn't need 4WD traction and the lanes were generally clear so switched the truck out of 4WD due to binding concerns. I'm not sure how 4WD helps during braking but if there is some advantage, let me know!
cofford
Seattle
2021 F-150 Platinum PB
Looks like you have a Powerboost, as I do. During any braking, the PB tries to recover battery charge using regenerative braking. In 2WD mode, this occurs using only the rear wheels. I've noticed my tires squeak while stopping at a light near my home, even during light braking. Changing to any 4WD mode (4A works here) causes no tire squeaks during a stop.
Since the regen biases even light braking to the rear wheels, which are already light, this is bad news in the snow. Use 4A at a minimum.
madsend81
East San Diego County, CA
2023 F150 PB XLT Sport 4x4, 157" WB
What trim level is your PB? If it's an XLT or lower, like mine, you don't have 4A, just 2H, 4H and 4L.. Lariat and higher have 4A available.
(just saw this never posted -- wrote this yesterday at 5pm :ROFLMAO: )
Yeah, don't use 4WD in those conditions in the XLT. PB has regen braking so what you may have been experiencing wasn't braking but regen on a slick surface. That will induce yaw. Might try 'slippery' mode in such conditions but make sure to put it into 2WD. Also don't lock your rear end. Putting ESOF in the PB was a big mistake on ford's part. You'd think they tested these things in Michigan during slick conditions but alas, we're here.
Bryan Simon
Bryan
San Antonio, Texas
Maintenance
I think the issue may be related to the PB and how it works.
Grew up in the mountains of Idaho
Ice—76 Chev 3/4 4x4 manual trans—not driving that squirrelly thing anywhere—-better suited for slush, snow, & snow pack
79 Chev 1/2 two wheeler (still have it) This thing ain’t going nowhere on ice. Gets stuck on the expansion joint in the driveway.
73 Plymouth Fury. Heavy car, soft springs, Michelin X radials.
Extremely sure footed on any road condition. Enough weight transfer to get it going and stopped, and was a comfortable ride as well
Later in Utah—78 Chev full time 4x4. All time favorite for bad roads but terribly rough ride. No getting out to lock hubs. Non computerized version of the current 4A. Came at a cost, less than 10mpg in any driving condition.
Never Mud&Snow tires on any of these. Hiway tread on all but that 76 that had all terrain.
SonarChief
Stephen
Connecticut
2024 F150 King Ranch, 153” WB, Anti-Matter Blue PB
Systems Engineer
I used to run Blizzaks on my 2010 sport trac, unstoppable in snow! BUT, the expense for the tire vs its single minded abilities for one season in Connecticut made me want to get a tire that was very good in snow, but also worked as a very good A/T tire. So for my 2024 KR with 20 inch wheels, I went with Pirelli Scorpion A/T plus using stock sizes. These didn’t weigh much more than the stock Scorpion A/T’s. We had about 5 inches of snow the other day, so went out at 4Am to test the truck for its first real snow. Used Slippery Mode on the main roads, which were only partially plowed at the time. This puts the truck in 4A, and reduces rear brake regen and its reported rear end “ squirrely” issues. Did several light and heavy braking stops, saw zero issues on both flats and down hills with control, always straight ABS stops. Btw I have no added weight in the rear. Then I went to a back trail that was completely unplowed with 5-6 inches of snow, with both up and down grades. Put the truck in off-road, 4H with locking rear, and the truck was unstoppable!! Never spun any tires that I could feel, was very pleased!
ProperRCLB
Roger
New England
2024 RCLB F-150 5.0 XL 4x4
We have gotten plenty snow lately where I am as well. I went out on 7-8 inches of snow, 5.0 on 4H and Slippery mode and zero issues.
FaaWrenchBndr
Denver, IN
‘24 XLT Powerboost
It can also help too, put the truck into neutral when coming to a snow packed icy stop. It can help quite a bit.
SumGuy
F150 (perpetually on order)
Drugs
Dedicated snow tires are far, far superior to any all season.
You can get by without them, sure, but icy roads without snow tires just isn’t fun.
I live in Idaho. If the roads are truly bad we take my wife’s q5 with blizzaks. Drives like a tank.
