20ecoboost21
Georgia
2024 F150 Platinum
I'm waiting to hear back from Ford but has anyone come across this issue. I've been using FDRS for a while now with no problem.
Ford F-150 ECU module programming guide using FDRS Screenshot (524)
bjl95mustang
Pflugerville Texas
2024 F-150 STX 4X4 2.7
Fire Fighter
I got that error this last week. I just closed and tried to log in again and it worked fine after that.
JohnTrigger
MD
‘24 F-150 STX 2.7L SCREW
Scroll down on the FDRS Help on the login screen. Recently they had troubleshooting tips on how to solve login problems written there. One of the solutions was removing and reinstalling FDRS, and that seems to have worked lately for many people. It did for me.
Mach 1 Pilot
Alum Bank, PA
2021 F150, 2003 Mach 1, 1995 F150 Lightning
Hello - I found this thread while researching what I need to do to program a new Restraint Control Module in a 24 F250…. Which led me to FDRS - And it looks like there is no better thread about FDRS than this one. :). That being said, I went to the list of supported devices at the Motorcraft.com webpage and it says the Mongoose J2534 device suggested in the first page of this thread “provide support for model years 1996-Present with limited programming functionality”.
https://www.motorcraftservice.com/diagnostic/FJDSSupport?categoryId=247
The limited programming functionality note concerns me… This webpage mentions the Bosch/Rotunda and Snap On devices “provide support for model years 2018-Present with FULL programming functionality”
I know this is a F150 and not a Superduty forum…. But has anyone been able to program a RCM in a 24+ vehicle with the Mongoose J2534 device? In searching this thread I did not see any RCM programming mentioned by anyone, but someone surely had to try by now. :) For that matter, is there any limitation at all with the Mongoose vs the Bosch/Rotunda device?
Just want to make sure I do not need a Bosch Mastertech or Rotunda VCM to do this…. And find out after I buy a Mongoose.
Thank you!
I have never done this, but I can tell you the Mongoose is fully supported by FDRS and will work to program it.
windowsmedia10
Toronto, CA
2024 F-150 Lariat Powerboost, 2025 Lincoln Nautilus
Same thing that happened with the IPC update when @aviator updated the IPC on his 2024 recently.
And the same thing just happened to me on my MY24 Lariat Powerboost. Except you also have to disconnect the battery under the passenger rear seat to completely cut the power.
Ran the IPC update, followed all the instructions. Note that this update is a USB install, but also does some block related updates following the USB part.
Following the update procedure there was an audible clicking noise coming from near the driver side of the dashboard. FDRS said update failed, redoing the IPC update routine didn't work, and neither did a PMI selecting no for the original module install.
I disconnected the two batteries, gave it a few min, reconnected both batteries, reconnected FDRS and ran the IPC update routine again. This time it did not prompt me to insert the USB key and copy the update. It realized that the correct version was already installed, did some post update procedures, said successfully completed and the update disappeared.
Correct.....on PowerBoost trucks, you need to disconnect the small 12v under the rear seat, too.
poopy_pants
Brian
Wildwood, MO
2024 F-350 Super Duty
Thank you!
I’ve successfully updated my 24 F350 multiple times with the Mongoose and FDRS. Works great. My next adventure is going to be attempting to load the High Output strategy file on my Standard Output diesel via ForScan unless someone can tell me why it won’t work.
I don't know if it will work or not, but I can tell you that I sure would not shy away from trying it.
jfalat
joe
akron ohio
2024f150 crewcab xlt 3.5
truck upfitter
i use mongoose all the time programming f550 and f600 chassis at the shop.. it work great with FDRS.. I just got a vcm3 for the shop and i cant see any speed difference at this point..
Fordphanatic
Boothwyn
2021 Platinum F150
Union Carpenter
Have you tried this? Would love to try the same thing in my std 6.7 f250
poopy_pants
Brian
Wildwood, MO
Not yet. I updated a couple of other modules today and downloaded the latest HO PCM file. I may give it a try this weekend. I'll be sure to follow up with the results. I will likely log the boost, fuel pressure, etc before and after to see if it appears to have had any effect.
poopy_pants
Brian
Wildwood, MO
I was able to update the PCM today. I loaded the High Output version of the 6.7 Powerstroke file via ForScan. So that answers the question on "can it be done". It started fine and there were no DTC's. I ran some rather unscientific testing as that's all I had time for this morning. I have a Dragy performance meter I use on my BMW so I did a before and after 0-60 on the same exact start and end point within and hour of each other so temps and conditions were the same. Traction control and Advanced Track off with the rear locker engaged.
Standard Output (factory)
0-60 6.44s
Some wheel slip at start but not super noticeable after the shift.
High Output
0-60 6.35s
Slightly more wheel slip and more pronounced after shift.
Max boost seemed about the same on the dash. I usually see 30-32 when I'm accelerating regardless of the tune. I can't say I would have noticed any seat of the pants difference in drivability. I've heard Ford limits torque in lower gears. I'm not sure of all of the specifics so maybe the affects will come on at more highway speeds in 10th gear.
