farmtruckman
I didn’t change any country codes, you mean keep ignition and engine both on and then do a network scan?If you've already begun changing country codes that could be your issue, or you may just need a new GWM. When you do a module scan it helps to have the truck running as sometimes some modules won't show up otherwise.
It might be wise to PMI any module with a country code and that should revert it all to US. Always select "NO" to if the original module is installed.
Using forscan to overwrite the software on the GWM should also be tried -- haven't tried to update the firmware on the GWM w/ forscan so unsure if it's possible. Rugedraw should be able to see your part numbers with PTS for locating a replacement GWM. What module got corrupted that started all of this?
We updated the GWM with the USB and I think something went south there, though the update was successful. It probably had some old configuration, I am sure @rugedraw knows what exactly/possibly happened.
QQ: even if we get the new GWM - won’t the same bad configuration be applied on the new module as part of PMI?
