Gord0
You can guestimate.Is there a way to correlate these SW Updates to OTA update numbers or find additional info about the updates?
https://tonesto7.github.io/ford-pwr-up-info/
I did check the Tonesto link out and I believe I already have all of the updates installed and 1 or 2 not listed there. ThanksYou can guestimate.
So, SurfacePro 7 with W11 is a NoGo?Finally complete with updates! Took me 2x weekends (i.e. 2x licenses) to complete, but I think I'm fully up to date on a 2022 truck that had zero updates to this point.
Final SYNC version: 23291_PRODUCT Revision : 1049
Mistakes made along the way are below. All of these issues are documented in other posts, but re-posting here for others to learn from:
-My "modern" Windows 11 laptop would never work to connect to Ford and login. Tried older computers, one of them with Win 10, and they both worked with FDRS version 37.4.7 - would never connect with the current version (39).
-Tried to use an old 10A battery charger as the power supply - did NOT work. It couldn't hold the voltage high enough and caused the IPMA updates to fail. Fix: Purchased the charger/power supply suggested in OP, and that worked very well.
-The USB stick's volume name caused the USB updates to fail. Fix: Renamed the USB stick to "sync", and no more issues.
-My APIM update problems this weekend were my own fault, not Ford server issues. The issue was just that my old computer's hard drive did not have enough space left! Some of the downloads were in the multiple gigabytes. If FDRS looks like it gets to 100% download of a file, but then fails with a "cannot retrieve binary file", check to make sure your hard drive is not filled up.
Thanks to all of those offering your help and experience. I'm hopeful that the OTA updates might start working from this point forward - fingers crossed.
My Surface Pro 6 and W11 works just fine as well. Biggest issue is only one USB port, but it isn't the end of the world even if you don't have a USB hub to get more ports.
I ended up having to do a fresh windows install a few weeks ago to get fdrs to work. I was cleaning out stuff to make room and ended up messing something up at some point.Yes, to be clear, I don't think there is anything inherent in the updated Windows or anything that is keeping FDRS from working. It's probably something more subtle specifically with my machine. I actually suspect if I fully factory reset my Surface Book 2 (Windows 11) back to a fresh image, it would probably work fine.
