JEB
There are a couple of ways you can check your current PCM software level, but you’ll require some assistance. You can post your VIN on the VIN lookup thread and ask someone to see if you have any PCM updates available in FDRS. Alternatively, you can send your VIN to me, I can pull your as-built data and compare it to mine to see if they’re the same. If they are, you are current. Either will work.We had to manually install updates outside of FDRS that took me from having almost no OTAs at all (2.2 was only one received organically) up to what was essentially the 3.5.4 equivalent. The only update since then was the 4.2.1 OTA. I'm not sure if the PU 1010 would have been included in those, but basically the only update actually completed in FDRS was the last TCU one.
Is there a way for me to check and see if I received it/ if I didn't receive it via FDRS and I'm already at the 4.x series, would I still get it OTA at a later date? Thanks in advance!
EDIT: I found your VIN on another thread. It looks like your PCM is not up to date. Here is your software data
<NODEID>
7E0
<F110>DSNL3A-12A650-BFC</F110>
<F111>ML3A-12B684-JKA</F111>
<F113>ML3A-12A650-GNC</F113>
<F17F>1BE060F0</F17F>
<F188>ML3A-14C204-NEL</F188>
<F18C>7835072011153</F18C>
<F190>1FTFW1ED6MFB67945</F190>
<F1E0>PXNL3A-12A650-BFC</F1E0>
</NODEID>
The current PCM software at F188 for our trucks ends -VGE. You should have a PCM update available in FDRS.
