Battery Suggestions
BAMORY68
Tiffin Ohio
2022 F150 Lariat Crew FX4 5.0
Nurse
I've been reading a boat load of threads regarding batteries, well I'm in the market for one, factory battery finally bit the big one.
2022 F150 Supercrew 4x4 Lariat 5.0 FX4 with all the bells and whistles.....I'll also be tweaking the battery monitoring system through Forscan.
Price isn't an issue , just want reliable ...any recommendations welcomed.
Kanuck
Winnipeg, Manitoba
Retired Electrician
H7 or H8 AGM with a good warranty and retail chain incase you need a replacement.
When replaced, reset your BCM
Key on engine off
Brights flash 5 times
Brakes 3 times
Battery light flashes 3 times
Your done.
Babbage
Upstate, NY
2021 F150 3.5 XLT 302A FX4 PP2K 36GAL TOW
Wild horse rider
Get the Ford 850CCA AGM - link in my sig. Get the insulator blanket too.
I did this - it fits.
Kanuck
Winnipeg, Manitoba
Retired Electrician
I just changed mine. Went with a H7, 860 CCA or so, because I am cheap and the H6 OEM blanket fit the H7. Canadian Tire 5 year replacement with 100 month pro rated.
Highway 11
'23 F-150, '24 Bronco
Costco Energizer H8 AGM, 900 Cold Cranking Amps. Bought it mostly due to the warranty (5 year limited, 100 months prorated). The manufacturer is Clarios (formerly Johnson Controls) and they have a good track record. After my experience with Motorcraft batteries in this truck and in my work fleet I wanted to steer clear.
BAMORY68
BAMORY68
Tiffin Ohio
Nurse
I'll ask my fiance about this (who is a member of Sam's ) I'll hear the
" those bunch of f***** liberals" ? ? ? but ty , I do love a good warranty
belairbrian
brian
Alabama
2022 F150 XL STX
I went with the Interstate H7 for my STX. Always done well with Interstate and at $169.99 from Costco no one could beat it. Tried to use the H6 blanket and it ripped. Got The bigger one ( KL3Z10A687B ). fit great.
Chappy133
Charles
Easton, PA
2022 F 150 Lariat 3.5 EB
Retired US Army
Got an H8 battery for my 2022 Lariat today from Walmart. When doing the BCM reset I never got the battery icon in KOEO with the door closed. I did get a low state of charge warning message. I did the BCM procedures 4 or 5 times. Anyhow it seems to be working since the engine shuts down at lights now.
Je1279
Jared
Upstate NY
With mine, it took 5-10 seconds after the BMS reset procedure completed for the battery light to flash.
Chappy133
Charles
Easton, PA
Retired US Army
BMS did reset. The truck is happy. Engine shut down on stop that hasn't worked for months is working again. Turned back on fold mirrors on lock and approach lighting again. I did get the H8 battery insulator from the dealership a while back. If your H6 battery is tired I highly recommend going to the H8.
BAMORY68
BAMORY68
Tiffin Ohio
Nurse
Did get the H8 for the truck, amazing how everything does work now again, but it is also ridiculous how dependent these trucks are in a battery compared to the old day, but happily satisfied. Got the Die Hard H8 from Advanced Auto , had no prorated warranty for 48 months , and I added a little more on top of that with extended protection. Reset BMS , and haven't had a bit of issue or notification since , been 2 weeks
Peace and Happy Thanksgiving
Tnker
Pa
23 f-150
Yesterday on two 45 minute drives my battery was showing 66% SOC and was charging at 1 amp… guess I’m going battery shopping for Black Friday
