Paul Neubauer
Are all the pistons still moving?
It only takes 6 revolutions of the engine for the timing to be off, and piston to valve tappy tap.have all cylinders sitting on the compression stroke with a valve open is perplexing.
Once again, the statement was made with the preface of, there has to be valve train damage or a chain jump.Wouldn't that depend on how many valves are bent (if any), like the guy above me said? I agree that under normal conditions all valves open would be impossible.
It's been out a week and has already found a way to speed itself up to double its launch speed.Damn, that seems pretty good for ai. At least at a quick glance it seems plausible.
yes, this one is crazy for sureMe too. I have built dozens of engines over 55 years and this is a first. I have experienced bent valves b4 but nothing as to cause compeat lack of compression with no apparent valve train noise when rotating under starter RPM. It rotates smooth and noise free.
I will up date.
OAI started by 'stealing' all of the data on the internet it could with zero respect to the copyright holders. In fact one of the biggest problems for the past year is that all of the models have consumed all of the internet and the models need even more input. As such they're having to generate artificial inputs to grow them now. Thieves really don't have any agency to claim loss over ill gotten gains.Not bad for a model that teaches itself by stealing its data from other AI. Typical Chinese. Lol
Just depends on which way the chain jumped or skip relative to rotation. If the chain jumps in an advanced position, the intake valves would still be open on the compression stroke, and so the pistons would hit the intake valves. If the chain jumped in a retarded position, the exhaust valves would still be open and damage those?I hope your wrong too.
Why do you think it's intake? I listened to the intake manifold and didn't hear anything. That's what I do during a compression test on aircraft engines. I listen for leakage on both the intake and exhaust. If exhaust we tap on the valve with a hammer to feel the movement and see if valve is stuck. I couldn't get my ear up the exhaust and turn the key at same time.
Also wouldn't i hear the tap tap tap ?
