SeattleGuy
Seattle
2023 F150 Lariat Powerboost
Did you do a SAVE before any changes? If so, should be able to upload the original module settings.
I believe I saved each module before making any changes.
But I am just second guessing myself because it is still having an issue.
SeattleGuy
Seattle
if you are using forscan you can go to as built and reload the module back to OEM.
Do you know if there is a way to just reload all modules? I am wondering if I made a change to a module I did not keep track of.
Kanuck
Winnipeg, Manitoba
Retired Electrician
I suggest you PM Jesse-Infotainment and ask him. He may be able to help.
jfalat
joe
akron ohio
2024f150 crewcab xlt 3.5
truck upfitter
i believe you need to do each module separately. maybe some else can add to this.
Kanuck
Winnipeg, Manitoba
Retired Electrician
Depending how long ago the changes were made and if the truck has or hasn't sent the changes to the Ford servers, he may or may not be able to just PMI a module. If I understand correctly, PMIing a module will reinstall the original file from the Ford server if his changes have not been sent.
SilverPigeon
Australia
@SeattleGuy, Something you can try in FORScan is a module reset in case the module hasn't read its settings yet / properly during the key cycle.
dolsen
KY
2022 Rapid Red 701A
One thing I often see if people loading previous profiles and then trying to overwrite them, and not getting the desired changes. When you log into forscan and it asks if you want to load a previous profile, select NO, and force forscan to reload all modules. Then attempt your changes
LouDog
Sean
Grand Junction CO
21’ Lariat Powerboost
2023 Lariat Powerboost
Anyone have thoughts on what I could have done to my Rain Sensing Wipers and my rear passenger seat heater?
Whenever I mess with Forscan I seem to disable them. I think I reset all the modules back to stock but they still do not work.
Anything specifically I should look for?
Is there an easy (and safe) way to completely reset all the forscan settings back to stock? In case I messed with something I didnt realize.
I did my best to replace all the modules to stock that I touched, but still did not fix it. Makes me think I made some change I did not reset or realize. So would like to start from scratch.
Thanks
I’ve run into this before. If you have profiles set up, go into the guest profile and turn rain sensing on. Then go back into your profile and it should work.
Paul Neubauer
Paul
I had a 2023 Ford Edge as a service loaner a while back and it showed your elevation on the Sync screen. Is this possible to add to our screens using Forscan?
Dvcpro13
Matt
Kemptville Canada
2021 F150 Lariat 3.5L Ecoboost 502a Agate Black
Is it possible to get a second free extended license, after your original runs out? I thought I’d read that you just put in a new request and it generates a new key, but it doesn’t seem to be working for me.
1 year is really not that expensive. I supported the developers and bought a year after the trial.
SeattleGuy
Seattle
Damn. That might have been the solution! I just changed/fixed it and they are not currently going off. Will have to hit it with some water or wait for it to rain, but this might be the winning solution. Thanks!
AutonomousHybridF150
Kristopher
Pensacola Fl
2021 F150 Powerboost
Adjuster
If I recall that mode forces 4x4 and rear locker on and can't turn off. Not useful for general usage.
There should be a big warning saying that. I almost died when the deep snow turned to solid ice. I was not aware the rear end was locked up and so I almost lost control. Should not do that on hard surface dry either. Agreed.
Bob Violence
Bob
TX
2021 F150 Lariat 501A FX4 Powerboost
Is there a way to get rid of the chiming for the “no keyfob deteced” seems ford did an update recently that changed the sound of it to be even more annoying than it previously was. Ive looked through forscan and couldn’t find anything that seemed would work.
Looks like I'm following this thread again in hopes someone figures this out. I got current with FDRS about a month ago, and this new "no key detected" nag screen and sound is annoying AF.
superfordman
Troy
NE CO
2024 Raptor 801A
Precision Ag Guru
Hey @Livnitup with some assistance/encouragement from Jesse and others, I think we discovered that if you write 7E0-162-02 XXXX XXXX 01XX in the PCM, this will disable the active air dam. So either disable it on the truck currently, or for many of us who have it removed, gets ride of the silent DTC it always throws since it can't see the actuators anymore.
