Livnitup
- #2,926
Yeah, I concur with that and I've updated the PCM spreadsheet with some new definitions that shows exactly that and I'll add this to the common spreadsheet as wellHey @Livnitup with some assistance/encouragement from Jesse and others, I think we discovered that if you write 7E0-162-02 XXXX XXXX 01XX in the PCM, this will disable the active air dam. So either disable it on the truck currently, or for many of us who have it removed, gets ride of the silent DTC it always throws since it can't see the actuators anymore.
Also: once the newest IPMA update available in FDRS goes mainstream via OTA then I'll consolidate the IPMA spreadsheets in a single sheet since 2021-23s will be at the same level. For guys that already did the update you can reference the sheet called IPMA (BC 1.4).
