Newest Forscan Spreadsheet
BAMORY68
BAMORY68
Tiffin Ohio
2022 F150 Lariat Crew FX4 5.0
Nurse
Yes…. Line 77 in common tab
Removes black box on reverse camera that says "full view not available" APIM 7D0-02-02 xxx* xxxx xx-- If your current value is 0 then change to 1, 2 change to 3, 4 change to 5, 6 change to 7 Note: reset APIM after the change
Great , I'll try this when I get a free moment. You guys are on it ....someday I hope to contribute like you guys or ladies do
NickT_
Nick
Alabama
2021 Ford F-150 Platinum 4x4
Before you get started watch videos and read his instructions cause you do not wanna mess something up cause it will take time to fix it!
ALWAYS save the as built files for every module you are planning on changing. It will be easier to fix something if you done it wrong cause you have the original number/letters saved. I also take pics just to be safe.
astrand1
Alex
22 Ford F150 Powerboost 7.2kw
Studio truck driver
This! And will add to that what I do. So after I make changes and I’ll let some time pass to make sure there are no negative issues from what I’ve changed and all is working well. I’ll then go in and re-save all the modules that I made changes in so that if there is an ota update or I do FDRS updates and it clears out the mods I’ve done them it’s just a quick reload to get everything back where I had it. Over time once you make changes in forscan your truck will report it back to the mothership and your “as built” files will update but it’s hard to say when that happens so this is just what I do to make life easy.
NickT_
Nick
Alabama
Same! But if you save another “as built” make sure you don’t erase your “original as built” name the new one mods or something similar. Always keep your original as built handy.
astrand1
Alex
Studio truck driver
Good idea. Should have mentioned that. lol.
BAMORY68
BAMORY68
Tiffin Ohio
Nurse
This is good advice , I will definitely read and watch tutorial before I tinker around with the brain boxes ?
astrand1
Alex
Studio truck driver
Also worst case scenario if something did get messed up you can go to motorcraftservice.com and download your complete “as built” files. But you should be fine. ?
roadPilot
SE Michigan
Your AsBuilt will eventually get updated with whatever you changed. I know this to be true for 21+ trucks.
NickT_
Nick
Alabama
I seem to remember that Glare Free is not available for 2023 F150 Raptor. My lights seem to behave strangely, lights move around when first turned on. Also shift left and right when turning.
They are supposed to do this on start up and when you turn left or right. adaptive headlights is what they are called I believe.
Also you should have LED Projector headlight so you should be able to do glare free I believe. Post in the FORScan post and ask and maybe someone can confirm it.
https://www.f150gen14.com/forum/threads/2021-f-150-forscan-list-database-spreadsheet.1578/
AltaBrig
Brig
Southern CA 80% Western US and Western CA 20%
2023 F-150 Powerboost, 2013 Cmax Energi, 2011 Subaru Outback 3.6
Thanks! This is a main reason for me getting forscan and the ex in the near future. I just got the Vlinker fs and lite for the on the fly diagnostics.
I had that screen on multiple times to check the tiedowns and suspension on a lightweight kayak/gear trailer over 4k miles this summer. That black box drove me nuts.
You guys have probably put up enough beta like this that a software no talent like myself can avoid brickin' the truck and turn on and off a few bells and whistles.
Based on limited reading and searching I am guessing the full suite will reset bms, allow me to do brake fluid and pad changes, things ford has made it harder to DIY without resetting codes or running tests, etc.
