Jmitchelltfo
The way I understand it (maybe @HammaMan, @Snakebitten, @FaaWrenchBndr or someone with more knowledge than me can chime in)When I turn my truck on in the morning, the OBD Mx+ is showing resting volts(because the engine isn't on) and it's always above 13.1v
When you turn your truck "on" the DC/DC charger kicks in immediately. At least that is what I have noticed. My pickup doesn't care whether the ICE is engaged or not, it will charge the 12v batteries at whatever the low level setpoint is listed at on my MX+.
If your AGM batteries have a resting voltage of 13.1 (or above), I would be surprised. You are probably seeing 13.1+volts depending on the fan speed (and that is what your batteries are being charged at). After years of using AGMs in boats/trolling motors, and different vehicles, mine normally have a resting voltage between 12.7-12.9........ unless they were just pulled off the charger.
The only reason my AGM batteries show 13.15-13.25 for the resting voltage is due to the parallel setup that links a 20ah LFP to my OEM auxiliary battery. 10 minutes of work and next to zero modifications thanks to the efforts of Hammaman for R&D on his LFP to make sure it played nice with the DC/DC setup.
