Rossi6998
Surprise, AZ
2023 F-150 Tremor, 2024 F-150 XLT
Apparently Krud Kutter rust remover is not available in the states, but the Rust-Oleum branded version is. Or at least would be if it wasn't out of stock everywhere. :cautious:
FYI - As of 09/19, Amazon has the Rust-Oleum branded version in stock (both the spray and gel).
Porpoise Hork
Bret
IT Sys Admin
Now if only Amazon Logistics could just figure out how to deliver it without busting it open spilling 2/3 of the bottle I'd be set...
Oakridge88
The land of rainbows
2025 Ford F150
  • 1990s–2000s: OSHA and EPA regulations began phasing out or restricting high-VOC and hazardous solvent products, pushing manufacturers to create safer, water-based, low-VOC rust removers.
  • Today: Most consumer rust removers (like Evapo-Rust or naval jelly alternatives) are water-based, non-toxic, and biodegradable — largely due to EPA hazardous waste and disposal regulations.
  • Like
Reactions: Rio
Rio
Rio
Darren
kenora
2024 F150 XLT 3.5 Ecoboost
Looks great. I'll need to get some.
What product will you be using for paint? I've been wondering about something that can be brushed on to avoid overspray on everything. Would something like Por15 be a good option?
Funny you should ask, I bought 2 cans of Rustoleum then just yesterday when I was about to paint I realized how much of a mess that would make and how much masking would have to be done to eliminate the mess so I opted for a can of paint to brush on. I looked into the POR15 to brush on but they require a top coat which is ONLY in spray can! I opted to try semi gloss black Tremclad, it went on nice , one coat was probably equivalent to at least 3 coats spray. The brush worked well as you could push it into all the nooks and crannies, lol. I let it cure for 24hrs now heading back out to give it one more coat. Time will tell if this paint holds up to the elements
Rio
Rio
Darren
kenora
Oh crap!!
Mszczewski
Milwaukee, WI
21 F-150 Lariat Powerboost
That warning icon, just don't get it in your eye, crawling under the truck to spray!
Ford F-150 Rust remover tip!! Screenshot 2025-09-19 at 10.55.31 AM
Roaddogg4040
Steven
Roseville Ca
2025 F-150 XLT SUPER CREW PB 4X4
Retired Construction Project Superintendent
Got some good advise on here so it is nice to finally give a little something back, hopefully it is useful
I guess that I’m finally at the age that I’m not going to get down on the ground and look at the rust or actually anything else under my truck.🤷‍♂️🤣
Now a days I just hope that everything’s ok under there. Lol
Rio
Rio
Darren
kenora
I plan on keeping this truck for many, many years and with all the salt they use on the roads in my region I am going to do the best I can to make this truck last . lol! It will probably be the last truck I ever own. 😁
timnohio
Tim
2024 Ford F150
Here is how the brush on Tremcad paint turned out
Wow that does look great. I've got to try and do it to mine now. Thanks
Les_Garten
Les
FL
F-250
This stuff is impossible to get in the US. What is the name of the Rustoleum equivalent if someone knows?
RcFlyer330
Cameron
2022 F150 Limited Powerboost
Rustoleum rust dissolver
You should be able to find it locally.
Ford F-150 Rust remover tip!! 1758604223397-q9
