Powerboost Cavitating Noise on Cold Start
Erikp16
Erik
Calgary, Alberta, Canada
2021 F150 Powerboost
Now the cold weather is back in Calgary, Alberta, Canada. I am monitoring the cold start problem of my Powerboost again. I noticed this noise about October-November of 2021, the first winter of my Powerboost. I didn't get to record it until about February 2022 when I noticed it more. I went to the dealer about it, couldn't replicate it. Until I left it overnight and went there in the morning to cold start it together. They were able to hear it, but they cannot replicate it in the shop, that is because it warmed up already. It is annoying how they cannot fixed things. Anyway, they contacted Ford Engineering (that's what they told me) and their reply is "Normal". I do not think anything is normal about this. I plan to take this back again sometime this week and hopefully get some action on it.
I see more and more posting about this problem here. Anybody here had a resolution already? Did Ford Representative actually reply for an action or possible solution?
Here are the two videos I posted on youtube
November 6, 2022
February 2022
Thanks!
flasch192
Jeremy
Fond Du Lac, WI
2025 F150 1993 Mustang Cobra
Engine Assembly Tech
Unfortunately dealers say it normal , ford has no fix , traded my 21 PB for a 22 3.5 eco because of it !
Erikp16
Erik
Oh really? That is annoying. Unfortunately for me that is not an option unless Ford does the trade at no cost. I guess I will have make a lot of noise to hopefully get their attention.
hedge
Alberta
2020 F350
Something to look forward to when I get mine I guess :(. Does it still make the noise if you plug it in? Likely unrelated but just curious.
Erikp16
Erik
Oh yeah. I assume you are talking about the block heater? There’s a lot of assumptions about oil level, or the way you park it if it is nose down, or just the location of the pump itself. Not sure if Ford actually bothered to look into it.
snyce1
Steve
Schenectady,NY
21' F150PB PLATINUM, 17'Escape, 15'expeditionEL
November 6, 2022
February 2022
Thanks!
Have u tried using ethanol free gasoline?
So whatever the symptom is, it's not related to the ICE?
I ask because doesn't the Powerboost have the same exact ICE as the 3.5 Ecoboost?
Erikp16
Erik
Not related ICE, I think. I never heard any problem like that with non-Powerboost trucks.
Just listened to the video.
I'd sure like to see that truck up on a lift while it's making that racket. As loud as it is, it'd have to be easy enough to narrow down the source, even if you might know WHY it's doing it.
RossRR
Ross
Minnesota
22 Lariat 502A Rapid Red SCrew PB FX4 MaxTow
Sounds like fluids being pumped through a restrictive hose. Could it be you battery coolant being pumped back to warm the battery?
AndrewMC
Andrew
Gray, ME
2021 Powerboost
FF/EMT-B
Glad I'm not the only one who has this issue... Guess it's what we get for getting a first-year model of something
AndrewMC
Andrew
Gray, ME
2021 Powerboost
FF/EMT-B
That was my guess, since as people are noting, not an issue with the 3.5 non PB models
Hrm, sounds like the noise is being amplified by the exhaust, which means it's on the exhaust. Right where you put the camera under the truck is the location of the exhaust heat scavenging unit. That's a plate heat exchanger full of small passages. If I had to guess another possibility is if there's a portioning valve that meters the coolant flow. Cavitation possibilities increase if the line pressure is much lower than you'd expect it to be -- cold can do that, but it should be much lower than you'd expect to be present in a vehicle with hoses that are very flexible.
Did you check both coolant reservoirs?
Erikp16
Erik
Right? That’s one problem is the moment they move the truck to the lift the noise is gone. The trucks needs to be parked outsid, sit outside overnight, and the temperature should be at least (-11C, 12.2F) somewhere in that range.
