mongolodeon
Today I picked up my 2022 PowerBoost Limited from a dealership and found that they had not solved a problem where the SYNC system cannot check for a software update (which is a separate issue altogether). They brought the master tech out to the parking lot and he attempted to reset a module(s) hoping that it would do a complete enough reset to cause SYNC to fully reboot and then be able to check for an update OTA.
To do this he disconnected the negative cabling from the 12V battery and left the positive side connected. Then he took a small wire with alligator clips at both ends and clipped one end on the positive terminal (still attached to the battery post) and with the other end tapped it on the negative wiring (which was not attached to the battery post). There was a small puff of smoke and we heard some clicking from the engine compartment and the master tech was clearly surprised by this, remarking that "there must be another battery" and then mumbled about how there's another very small battery for the GPS antenna but that it shouldn't have caused what occurred. He didn't try again, so it was just the one time and it was fairly brief.
He then told me to start the truck and it started normally, but SYNC had not done a full reboot as he had intended and the software update page still just hung, trying to check for an update. He then said to bring the truck back for another appointment and he'd do a manual software update of SYNC using the shop laptop. The truck behaved normally for a few short trips after that.
Has anyone ever heard of something like this and is it possible that the technician did something that damaged the truck (electrical system, hybrid or 12V batteries, other sensitive modules) but won't be apparent right away? I would never think to do something like that but given that the service advisor brought him over and introduced him as a master technician and the most knowledgeable person in the service department regarding the PowerBoost and SYNC systems I deferred to his experience and expertise- yet I am disturbed by his reaction and surprise at what happened and it was clear that it wasn't the result he expected.
Just want to make sure my truck is not now compromised in any way as a result. I also plan to bring it to a different dealership to try to resolve the software update issue.
