mongolodeon
- #16
My gawd, this is giving me nightmares. As far as demanding an extended warranty from the dealership, I already have Ford ESP for 8 years/100K miles. Also, this dealership even when they mean well are just rip your hair out frustrating to deal with. For now my plan is to at least have the SYNC software update done manually by a different dealership and in the meantime I've asked the service advisor at the one that did the short circuit to document what they did in detail. I don't have high hopes that their documentation will be adequate on the first try.There's no telling what long-term issues could crop up from this. The aux batt B+ is wired into the BCMC under hood. The - portion is attached to the back of the cab and transfers energy through the cab itself. Various grounding locations are located throughout the cab much closer to where the negative battery terminal connects to the cab, where the short occurred.
I'd have this situation well documented (bitching at the dealer about it as well as calling ford corporate about it) and accept nothing less than a full extended warranty at their cost.
Everything from the PCM to APIM and everything up at the front of the truck may have shortened life. The battery isolator could also end up with issues as the short went through it. The PB was designed to not even pass ICE starting transients into its electrical system (everytime the truck starts while rolling the entire electrical system is isolated from the underhood batt).
There could be random issues that just start showing up immediately or they may end up presenting at a later date. There's no way to quantify the stress this event placed on the various ECUs within the truck. The 7ah batt isn't large and a short like likely quickly dipped the voltage well outside of expected norms.
