H8 Battery upgrade
FoMoCo1955
RT
Central Florida
2023 STX 4x4
Retired Ford/Lincoln Service Manager
I'm just about ready to upgrade to the H8 battery, but a question to those who have done so already, does the battery cables (mainly the positive cable) have enough slack (for lack of a better term) to reach the post, as the H8 Battery is about an inch to inch and a half longer? thanks for your help!
ChemGuy
Cole
Wisconsin
2021 XLT Sport 5.0
Chemical Reactor Operator
Cables were long enough on my 21 5.0
Also fwiw I've read that some people have had to replace the battery blanket, with a little convincing that also fit just fine on mine.
Cheeeese
Anthony
New York
2023 F150 XLT
Just replaced my H6 with an H8 on my 23 5.0. Cables worked fine, but did replace the blanket with the 3.0 diesel one (Did not attempt to squeeze the smaller one on)
My 2ND Ford
Ny
The cables were plenty long on my 21 3.5 eco. I replaced my H-6 with an H-8 last month and had no problems. I did not replace the battery blanket.
Walter Townsend
Walter
Nelson, BC, Canada
2021 F150 Lariat FX4 Off Road Fishing Edition 5.0
Owner Operator Starlight Tool Services Ltd Millwright/Welder/Machinist/Electronics tech
21 Lariat 5.0L, blanket was in rough shape so replaced. Cables fit fine, dealer covered both under warranty as they had changed the battery just before I got the truck and used the wrong battery, H6 but it said right on the battery, Not For Stop Start Use!
2022 F-150 Lariat SuperCrew 3.5 Ecoboost
22 Lariat 3.5 EB. Like @Walter Townsend , the blanket was in rough shape, so replaced it with the bigger one. Cable is long enough, if a bit tight. Like others have said, if you remove a tie wrap\cable holder, it gives it that extra length. I did not do that, as I think the cable is fine. No issues since.
EcoB259
GB
22 XLT S Crew
22 EB. I replaced w/ H8 I did not put new blanket on an he’ll hasn’t froze over yet.
It was over a year ago I did this and no more issues since I did it.
Chappy133
Charles
Easton, PA
2022 F 150 Lariat 3.5 EB
Retired US Army
22 EB. No issue with cables. I did buy the larger blanket on eBay. No longer getting those low state of charge messages ?.
gundam1967
Augustin
Georgia
2022 Ford F150 XLT Sport
Cables long enough on 22 V8. Bought a blanket from a Ford dealership in another state because it was cheaper than most websites
Polo08816
MD
2014 BMW 335i
Do you have a part number for that?
Xman
N Texas
2024 F150 Lariat PB 7.2k
My 2024 PB has a H7 battery. There does not appear to be enough room to install an H8 battery. Is there a change from earlier PB that no longer makes installing an H8 in a PB feasible? Can you still use an H8 in a 2023 PB?
