Forscan speed sign recognition
superfordman
Troy
NE CO
2024 Raptor 801A
Precision Ag Guru
can anyone elaborate on this?
A good chunk of the 22 trucks have both navigation and sat radio deleted. Some only had nav deleted and actually had sat radio since that is done in the ACM and not the APIM.
JJSnell
JJSnell
CdA, ID
2022 F150 Platinum FX4 PB
Wait so that stupid little MPH thing is from camera recognition?
I thought it was from Nav in your truck?
'Such and such road is 35mph', so it just tells you...?
Learned a new thing today...
Ford F-150 Forscan speed sign recognition 1000007573
22Platinum
2021 KR 3.5
software engineer
Oh dang I was hoping someone knew a Forscan to delete SiriusXM
Rineland
New York
2022 Ford F-150 XLT 302A 4x4 CCSB 3.5L EB
I would imagine it is possible to remove SiriusXM as a source using Forscan. I think you would do the opposite of those of us that have added it back in (myself included).
These are the lines I changed to re-enable SiriusXM.
7D0-01-01 *xxx-xxxx-xx This value went from 8 to A. If you have SiriusXM, I imagine this is already an A for you and you would change to 8. If it's not an A you will need to check Livinitup's spreadsheet to determine what it should be changed to in order to keep everything existing but disable SDARS.
727-01-01 *xxx-xxxx-xx This value went from B to 3. Instead of B to 3, you would change your 3 to a B. As mentioned above, if it's not a 3 already, the spreadsheet would need to be reviewed to keep the other fields the same but have SDARS disabled.
Below is the thread I used to get SiriusXM back if you want a reference.
https://www.f150gen14.com/forum/threads/my22-adding-siriusxm.14798/
superfordman
Troy
NE CO
2024 Raptor 801A
Precision Ag Guru
Its from both lol. It will display the speed limit based off gps, but then update and change if it reads a different speed limit from a sign.
mdomicolo
Matty
North Jersey
22’ F-150 Lariat 501A
Union Electrician
After some reading I think im going to skip the attempt at enabing the Sign Recognition due to the lack of navigation. With that said do you think the turn by turn changes will still work if I just change those two values?
720-05-01 xxxx x1xx xx—
720-10-01 xxxx xx4x xx—
I’m wondering if this will work with google maps? It seems my truck only shows the turns and stuff on the Speedo cluster for Apple Maps, but not google maps.
SilverPigeon
Australia
The bolded settings for 7D0-01-01 are what I used to disable SiriusXM and ignore any DTCs it might generate:
Ford F-150 Forscan speed sign recognition IMG_4490
I haven't found a way to do it for Google maps ?‍♂
mdomicolo
Matty
North Jersey
Union Electrician
Ahhh okay. I probably shouldn’t have made all those changes, because my non nav truck already did it with Apple maps. I think I’m getting a DTC now too from the IPMA
1lowcourier
Jeremiah
North Carolina
2023 F150 stx
Golf Course Construction
So after upgrading my '23 STX with the 8" cluster I've messed around a bit to get the speed sign recognition working. Right now the speed limit comes on white after passing a sign then grays out and goes away sometimes. I also noticed that it's not on the nav screen anymore. Am I doing something wrong. I followed the codes posted earlier.
Rineland
New York
If you have built in navigation, your values will be different as it’s going to get info from the navigation unit as well as the front camera. These changes were for those that do not have navigation or had it removed due to chip shortages.
1lowcourier
Jeremiah
North Carolina
2023 F150 stx
I do have nav. So do you know where I would be able to find the correct ones. I've been searching without much luck. I've been trying to use the spreadsheet but can be difficult
Rineland
New York
706-02-01 *XXX XXXX XX— is where you want to check. The other lines should be the same. We’re using 5 for our non-nav trucks. 6 or 7 will change the mode to “fusion” and will use data from the nav unit as well as the camera. You’ll have to check the spreadsheet to make sure your other features remain the same while turning fusion on to determine if you should use 6 or 7.
1lowcourier
Jeremiah
North Carolina
2023 F150 stx
Right on I appreciate that. I will have a look. Thank you
Je1279
Jared
Upstate NY
If it helps, I have the navigation, but couldn't get the speed sign recognition to work beyond what you mentioned above using the fusion option. I kept it though because it is more accurate than the navigation speed limit values.
