Hyins
Santa Clara
2023 F-150 Raptor
https://www.fordservicecontent.com/Ford_Content/IDS/FDRS/FDRS_40.4.5.exe
Hey guys just purchased 2 day license and first time trying to login to FDRS and I’m getting “User authentication failed”.
Using Windows 11.
Checked my credentials on the ford service site.
I’ve seen people having problems with the latest FDRS version 40.4.5 but can’t find where to download an earlier version.
any help would be much appreciated!!
https://www.fordservicecontent.com/Ford_Content/IDS/FDRS/FDRS_40.4.1.exe
https://www.fordservicecontent.com/Ford_Content/IDS/FDRS/FDRS_39.6.8.exe
https://www.fordservicecontent.com/Ford_Content/IDS/FDRS/FDRS_39.6.3.exe
bscottright
Riverside
2021 Ford F150 XLT
Hey there, I just wanted to say a huge thank you to this wonderful community for their amazing input! With their help, I was able to apply updates to my truck using a Mongoose and FDRS. However, after a day and a half of non-stop updating, I ran into a little snag with the BCM (G2161053-21.000). It's asking me to log in as an Automotive Security Professional, but I'm not sure how to do that. Do you guys know of any workarounds, or should I just head to the dealership? Any advice would be greatly appreciated! Thanks so much!
Ford F-150 ECU module programming guide using FDRS 1715451223862-y2
The ACM does not clear after you update it for many people including myself.
The BCM issue is a new one that popped up recently. After talking to Jesse about it, he thinks it is an issue with FDRS that Ford needs to fix. It should be asking for those credentials unless you are trying to program keys. I know if it affecting F150's and Lightnings and possible other vehicles, as well.
Mstephens20
Matthew
Clearwater Fl
2021 F150 PB Platinum FX4
Received this when trying to update the BCM. Does anyone know how I can move forward with the update?
Ford F-150 ECU module programming guide using FDRS IMG_4306
deagle2008
Jordan
BC Canada
Contractor
just make an account and try it. i registered with NASTF through Mongoose Toolbox software link
Mstephens20
Matthew
Clearwater Fl
I did click the link and registered but didn’t work when I tried to login with it so I moved on to other modules while I still had time.
My license expired so I’ll have to try again next time.
The reason I asked when your license expired because you aren't on the latest Sync version. However, in your case, that is the latest available until Ford releases more; there is nothing that can be done to get you to the latest for now. Nothing to worry about.....eventually it will be released and you will get it OTA or be able to do it yourself with FDRS.
Mstephens20
Matthew
Clearwater Fl
I’m just glad I was able to get the truck further updated for now!! Spent a ton of late night hours to get it done. Still had like 8 things to update I got some updates I was looking forward to like full screen CarPlay and on the FordApp it now says active for BlueCruise. Not really 100% sure if I have it or what but it didn’t say active before.
Do I need to worry about the BCM?? I want to update everything I can.
also…how do I get the cameras in motion thing I’ve been reading about?
I would not worry about the BCM. It will probably come in via OTA.
Cameras in motion can be enabled with FORScan:
https://www.f150gen14.com/forum/threads/2021-f-150-forscan-list-database-spreadsheet.1578/
IPMA706-02-02xxxFCExxxx--
APIM7D0-01-01xxxxxxxxFD--
APIM7D0-01-04xxxxFDxxxx--
JEB
2021 F150 Lariat PB 502a
If you registered for the free NASTF membership, I wouldn’t expect it to work. According to the pop-up you received, you have to be registered as a Vehicle Security Professional (VSP). VSP registration is not free and it is open only to professionals, like locksmiths, who pay a fee and go through a vetting process. https://sdrm.nastfsecurityregistry.org/dotorg/landing
In any event, this requirement will probably be removed by Ford at some point. It is new and probably an error. I did not have to enter any credentials the last time I updated my BCM.
Kanuck
Winnipeg, Manitoba
Retired Electrician
While your using Forscan, you can also get rid of the black nag box on the back up camera screen with this...
APIM7D0-02-02xxx*xxxxxx--If your current value is 0 then change to 1, 2 change to 3, 4 change to 5, 6 change to 7 Note: reset APIM after the change
Kanuck
Winnipeg, Manitoba
Retired Electrician
@rugedraw - when you have a moment, could you have a peek on PTS and see if I have anything outstanding of interest?
Thank you in advance
1FTFX1E81MKE01710
