"Steve"
thanks mike!ACM and an APIM update.
Yes and it will stay at internal process for a while so dont freak outToday's the day, fellas. Mongoose-Plus, Pro-Logix charger w/PS mode and a 2 day FJRS/FDRS subscription. The ABS module took about 4 minutes.
Now updating the CMR (driver status monitor camera) and related modules -- this one will take a while based on the progress bar.
Yes I often get this. I think it has to do with the software for Ford’s official VCM hardware.I recently (two days ago) installed the latest Mongoose (Mongoose-Plus Ford2) software (mongooseplus_ford2_0404_0500_setup.exe). During the installation, the software noted that it found a newer version, so I installed it. I then installed the latest FDRS software (FDRS_34.5.3.exe). Everything seemed to install without an issues. However, when I run FDRS, I get the following note that pops up:
I have not plugged the Mongoose into the truck yet. Is this normal? Has anyone else seen this? I plan to uninstall the Mongoose software and then re-install it from the downloaded setup file and then refuse to new version prompt during the installation. However, I didn't want to waste my time if this is expected.
Everything is going very well.Yes and it will stay at internal process for a while so dont freak out
Can I ask?Everything is going very well.
Every module that had an update available except APIM has been successfully updated.
For what it's worth, time from start to finish for each module:
ABS ~4 minutes
CMR ~47 minutes
WACM ~2 minutes
GSM ~3 minutes
BCM ~7 minutes
APIM is just over an hour and counting, still copying the ~5GB of files to the USB drive
I appreciate all the time and effort you and others have put into documenting this. I should have did this back in May 2022 and the dealership wouldn't have had my truck for 2 months and 4 days to get BlueCruise active ... LOL.
Full disclosure: I've been a member HERE since APR 2021, but I was keeping everyone updated over on "that other" F150 discussion forum.I ask because it's interesting to watch the various thresholds of pain of different inmates, before they cave.
And it almost ALWAYS leads to exactly your current experience where suddenly you realize that the service department at your local dealership really aren't folks that are more qualified to sit in your truck with a laptop.
It just takes a while before you can get your head around that.
I updated the APIM on my MME today, and I decided to see how much of the slow file copying was due to FDRS versus hardware. I used a M2 NVME in a USB-C adapter attached to a USB-C port on my laptop and it only took about 5 minutes for all 6GB to copy over. I then copied them off to my hdd (I always do this) and it took about 18 seconds to copy 6GB over USB-C from NVME to NVME. So FDRS does slow things down a bunch, but better hardware definitely helps. When I did my F150 I used an old school USB 2.0 stick and it was like yours, hours to copy the files over.APIM is just over an hour and counting, still copying the ~5GB of files to the USB drive
Thanks for the reply.Full disclosure: I've been a member HERE since APR 2021, but I was keeping everyone updated over on "that other" F150 discussion forum.
My ordeal was fully documented in a thread over htere that is now 379 pages (3,787 posts) and counting. I started posting my trials and tribulations around post 500. Two months and 4 days later (post ~1,222), my truck was set.
No, those were not all MY posts ... mine were mixed in with others.
Believe me, it wasn't a matter of incompetence. This was March 2022 - I was THE first customer to bring his 2021 Job 1 truck to that dealership and report the "stuck" OTA and also for them to apply all the outstanding SW updates to get BlueCruise going, so I was the guinea pig.
I had a loaner the entire 2+ months (I've bought 14 or 15 new Ford/Lincoln/Mercury vehicles from them in the past ~17 years and have a great relationship with the ownership.
If they weren't waiting on a new APIM (several were shipped to them, including one directly from Ford Engineering) and IPMA modules, they were trying to update it nearly every business day during the 2+ months.
This was BEFORE Ford updated the instructions to put the battery on a power supply/charger during programming, as the whole problem ended up being just that (they even had to replace my battery).
Suffice it to say, they and Ford engineering worked and learned together on my truck.
I didn't mind ... like I said, they took care of me with a loaner for over 2 months and we were in constant contact almost every day.
Yes, that was it. Thank you.Yes I often get this. I think it has to do with the software for Ford’s official VCM hardware.
I followed the link and updated the VCI software anyway just to be on the safe side.
Great for you!!Everything completed just fine.
No more SW updates for any modules.
Alexa built-in, Android Auto full screen, yada yada.
Start to finish, APIM took ~2.5 hours via USB 3.0 drive. 40 minutes to download the files from Ford, roughly an hour to copy them to the USB drive, inserted USB in truck and 15 seconds, it started loading, ~20 minutes later I got the "Restart required", shut down/opened door and waited > 10 minutes, closed door and started truck, finished allowing FDRS to compete and upload data to the server. There may have been a little time in there where the truck was actually done before I saw it, as I was in and out of the garage a lot, as I didn't want to just sit in there while it churned.
Note that I never got the "Update successful" message even after ~25 minutes of KOER (FDRS says you should get in about 5 minutes), but absolutely everything updated as expected and it all works.
FDRS shows no SW updates left and APIM update was successful. Can't complain.
Too bad I couldn't pay by the hour for FDRS ... a little more than 3.5 hours total, I think.
(More) full(er) screen AA. That's as big as the map goes. That card on the right isn't a
Sync card, but is from my phone (SiriusXM app, I think, or maybe Pandora):
Alexa @ Fordpass:
New button:
Off-road dash card is new:
Nothing today.Wondering if someone could check if there are any updates available for me? Truck is currently in at the dealer.
1FTFW1ED0MFB66211
23 Mar '22 build date.Any1 module updates for 1FTFW1E58NKD87010 ?
Agree 100% I use a SanDisk Extreme PRO USB 3.2 Solid State Flash Drive and the big APIM took about 10 minutes to copy files and 30 to load to the truck. The battery charger is the next item not to cheap out on. With the Power Supply mode it's worked great for me every time.I updated the APIM on my MME today, and I decided to see how much of the slow file copying was due to FDRS versus hardware. I used a M2 NVME in a USB-C adapter attached to a USB-C port on my laptop and it only took about 5 minutes for all 6GB to copy over. I then copied them off to my hdd (I always do this) and it took about 18 seconds to copy 6GB over USB-C from NVME to NVME. So FDRS does slow things down a bunch, but better hardware definitely helps. When I did my F150 I used an old school USB 2.0 stick and it was like yours, hours to copy the files over.
