rugedraw
Javier
Miami
Auto Sales
speedracercjr
Cory
2021 Lariat EB
O&G
It's weird how some people have issues with the latest FDRS on Windows 11 and others don't. I'm on W11 and have no problems running FDRS.
ENG430
Ahmad
Kuwait
2021 F150 Lariat 502A
IPMA & PSCM installed successfully without any DTC. Took Around 3 hrs (No BC).
Any idea how to enable cross traffic alert view?
Ford F-150 ECU module programming guide using FDRS 7BA8CC16-14E7-4DFA-98E6-BDAC6458445B
Addabob64
NTX - NNE of Dallas Area
2021 F150 PB 900A
Thanks rugedraw! Any suggestions as to how far back I should go in the revisions?
Quick update. I think it was user error on my part. I had installed 38.5.7 and during that process didn’t enter the Motorcraft user ID. So I think it was trying to login and had null credentials. I reinstalled 38.5.7 and was reprompted to enter the id when it first launched, and I was then able to connect without issue.
RickBullotta
Rick
Pennsylvania
2021 F-150 Lariat Powerboost
Is there any way to see the actual file date/times for updates from FDRS (firmware/software, strategy, etc). I'd like to know if the dreaded BCM update has been fixed yet, but there's really no way to know unless the file date/time changes.
Fordphanatic
Boothwyn
2021 Platinum F150
Union Carpenter
Is anyone else not having the updates clear from FDRS after applying. Did the IPMA and PSCM both appeared successful but won't clear from the software tab
JEB
US
2021 F150 Lariat PB 502a
You’re presuming there’s a problem for Ford to fix. I suspect there is, but Ford has said only that the BCM update is blowing out headlamps for 2022s. Nobody knows for sure whether it’s also blowing out the quads on 2021s because nobody’s said they’ve tried it. Nobody wants to be first.
JEB
US
I have had updates for other modules fail to clear immediately, but not these. Have you checked your as-built to confirm that everything went through?
If it ain't broke, don't apply the Ford fix unless you have to do it. I don't think BCM is OTA just on FDRS. If it's not blocking anything new leave it alone is my thought and I have 502a that should be safe.
Fordphanatic
Boothwyn
2021 Platinum F150
Union Carpenter
Not even sure where to look for that to be honest
JEB
US
If you’re not in a hurry, wait a few weeks. If everything went through ok, it should clear on its own. If you want me to look, PM me your VIN and I can look for you. We have different models, but I can compare what you have to what I have and see if there are differences.
RickBullotta
Rick
Pennsylvania
yup. But my concern is starting an update for another module that then triggers the bcm module update. So I’m staying away from all of the latest 4 (BCM, IPMA, PSCM, and IPC)
Fordphanatic
Boothwyn
2021 Platinum F150
Union Carpenter
So I ran a network test and the ipma cleared but not pscm
JEB
US
You’re probably ok then. Sounds like there might just be a lag in updating your as-built. You can periodically try a new network scan. Another thing you can try if you just want to look for yourself is use FORScan to pull up the strategy for the PSCM. Then compare that strategy to the strategy file on your hard drive that FDRS downloaded. If they’re the same, it likely installed fine. You can find the strategy file on your hard drive here: C:/ProgramData/Ford Motor Company/FDRS/fdrs/data/vehicle_software.
