rugedraw
Javier
Miami
Auto Sales
Is there a level of quality in the lane keep cal of the ipma? I did the cal when the roads were slightly wet this morning. Should I do it again once fully dry with better lane paint. Or if it passes, there no room for improvement?
I'm not sure, but I don't think so. It either works or it fails if it cannot read the lanes.
Doing my bi-annual updates on my 22 Raptor. I’ve got a pretty good list of updates including a BCM. Is this one safe to install or should I skip it?
It is safe. There are no updates you need to be wary of right now.
Gotcha I was looking through the spreadsheet, but I didnt see these values on the IPMA module. Would you be able to point me in the right direction?
You don't need to change anything in the IPMA for the calibration process. It is part of the service procedures in FORScan for the IPMA.
PizzamanJon
Jon
Bangor, Maine
2021 Ford F150 Lariat
Trying to get setup here to update my truck. Does the FJDS license give me access to the FDRS program?
Ford F-150 ECU module programming guide using FDRS Screenshot 2023-11-27 at 1.37.30 PM
RellIk&5
Wayne
Las Vegas, NV
2021 F150 XLT Black Widow
Interesting. I had a Driver Status Camera Module Update that took about an hour to complete. Odd that my Raptor got this considering we won’t get BC.
superfordman
Troy
NE CO
2024 Raptor 801A
Precision Ag Guru
Under the easy mode IPMA changes it is listed there, but unless you really changed the front height like I said, level, lift, tires, you shouldn't need to mess with it from factory.
PizzamanJon
Jon
Bangor, Maine
Starting the updates to my truck and as soon as I open the FDRS software I get this screen. Ive downloaded the OPUS software. Any thoughts?
Ford F-150 ECU module programming guide using FDRS Screenshot 2023-11-29 at 11.22.28 AM
JEB
US
2021 F150 Lariat PB 502a
Right under the link to install FDRS on the Motorcraft site you’ll see a link for VCI software. You won't actually use it with the Mongoose, but installing it will prevent that pop up.
Kanuck
Winnipeg, Manitoba
Retired Electrician
I just double click on the Continue...
PizzamanJon
Jon
Bangor, Maine
Thank you,
I purchased my FDRS license but it doesn't recognize it? Does it take a few to sync through? Double and triple checked that the license was correct.
Ford F-150 ECU module programming guide using FDRS Screenshot 2023-11-29 at 11.59.45 AM
JEB
US
Thank you,
Are you running Windows 11? FDRS 38.5.X doesn’t play nicely with Windows 11. You might need to install 37.4.7 or earlier. I don’t recall who but another member has links to older versions.
Cnixon
New Mexico
2021 F150 King Ranch
Unrelated side note, which one of you heathens is trying to get into my truck ?
Ford F-150 ECU module programming guide using FDRS Screenshot_2023-11-29-05-36-18-98_f85a9dcae275ee1e0920d804e6924647
rugedraw
Javier
Miami
Auto Sales
That is me. I'm trying to hack into your BC dash cameras so I can post videos of you picking your nose while you drive.
PizzamanJon
Jon
Bangor, Maine
Yes windows 11. I’ll look for older versions. Thank you
