rugedraw
Keep it going. The APIM one will pop up sooner than later.After finishing the IPC update one popped up for the GWM.
Waiting on the GWM to install now.Keep it going. The APIM one will pop up sooner than later.
Sync 23031, which I think is the FDRS equivalent of 4.2.2, was available for ‘21s as of last Friday. I thought 4.2.2.2 was just for the Mach-E.So 4.2.2.2 showed up on an F150 today?
Or was that old news?
Thought so tooSync 23031, which I think is the FDRS equivalent of 4.2.2, was available for ‘21s as of last Friday. I thought 4.2.2.2 was just for the Mach-E.
Weird. Description in the screenshot sounds like what was done in 4.2.2.
The second GWM is much smaller. Brace yourself for the APIM update—over 6GB. It’s gonna take awhile.Waiting on the GWM to install now.
No. What happens when you start the vehicle? Not just the ignition, full restart oif the engine (KOEO)?After waiting 10 minutes, it keeps telling me restart required. To complete the update, restart the vehicle. Does this mean I need to use the CAN BUS method?
Now nothing has popped up on the screen about the USB or the software update.No. What happens when you start the vehicle? Not just the ignition, full restart oif the engine (KOEO)?
Give it another five. If nothing pops up, remove the USB and tell FDRS the update was successful. Only say it was not successful if you see an error message. That’s what the instructions should say on your laptop screen.I've let it run for 5 minutes and nothing has popped up.
Yes, that's what they say. The first time I only put the ignition to on because that is what the Google doc guide said. It has been 10 minutes and still nothing.Give it another five. If nothing pops up, remove the USB and tell FDRS the update was successful. Only say it was not successful if you see an error message. That’s what the instructions should say on your laptop screen.
Leave the engine running until FDRS tells you the application is completed.
Follow the instructions on the FDRS screen. Ignore the Google guide, whatever that is.Yes, that's what they say. The first time I only put the ignition to on because that is what the Google doc guide said. It has been 10 minutes and still nothing.
10-4.Follow the instructions on the FDRS screen. Ignore the Google guide, whatever that is.
