Paul Neubauer
Should a self test be run on every module updated?The Self test on the DSM was in regards to the Climate seats
No, The dsm has the Memory seats, Power pedals, power Column and the Power Running boards if you have them. It also controls the heated and cooled seats for the front. So its best practice witht he DSM to run it. That is the re calibration for the steps and it will also verify functionality of the other things.Should a self test be run on every module updated?
I still need to get another license and run that self test. My running boards have been acting up ever since I updated everything to get Bluecruise.No, The dsm has the Memory seats, Power pedals, power Column and the Power Running boards if you have them. It also controls the heated and cooled seats for the front. So its best practice witht he DSM to run it. That is the re calibration for the steps and it will also verify functionality of the other things.
I think you can run the module self tests with Forscan as well.I still need to get another license and run that self test. My running boards have been acting up ever since I updated everything to get Bluecruise.
Anthony..could you check what module updates are outstanding on my truck as it goes in tomorrow to the dealer? I have had 3 updates since it was last checked and wonder what is outstanding. Maybe I can get them to do some updates.
@KanuckAnthony..could you check what module updates are outstanding on my truck as it goes in tomorrow to the dealer? I have had 3 updates since it was last checked and wonder what is outstanding. Maybe I can get them to do some updates.
Thank you in advance.
My VIN is 1FTFX1E81MKE01710
Thanks
TRM that's it.Can anyone run me for available updates, please?
1FTFW1ED3NFB12550
I have not found a good DFW dealer, and sounds like you are in the same boat. There is one under construction near me and several neighbors and I have our fingers crossed that they will be decent whenever they open. If you happen to find a good one, let me know.gah. fuggers didnt do module recovery csp.
yeah, this was rockwall. they took it back and said they solved the module recovery csp. i'll see if that disappears. kinda wishing i woulda mentioned the IPC update and had them do that.I have not found a good DFW dealer, and sounds like you are in the same boat. There is one under construction near me and several neighbors and I have our fingers crossed that they will be decent whenever they open. If you happen to find a good one, let me know.
Thanks for checking! That TRM is a recall right? Funny how the notification doesn’t appear on the FordPass app. I’ll have to get this updated.TRM that's it.
Not me, its only supposed to be a million degrees outside. Any time outside for me will involve a pool and likely margaritas. Good luck.anyone doing any updates in the DFW area this weekend? :eyebrows:
It's been like living in the arm pit of a jalapeño for the past couple weeks here!Not me, its only supposed to be a million degrees outside. Any time outside for me will involve a pool and likely margaritas. Good luck.
