Are these all factory tie down areas?
CaptDave
Erie PA
2023 F150 HEV; 2018 Explorer
Certified Marine Investigator
This is my first truck ever. Hopefully I’m using the right terminology as well. Can someone help me determine if these are all factory and do I need anything else to use ratchet straps?
The previous owner left two straps in the storage compartment and I am planning on buying a couple retractable ones. Thanks!
Your vehicle should have come with the tie-downs & a key to lock them in place that fit into the side mounted brackets. It not, they are available from any Ford Dealer.
Brandon8
Brandon
Maryland
2024 F-150 Powerboost Lariat
nurse practitioner
I bought used so who knows.
Henfield
Usa
I bought some amazon box plates and the plastic hooks that go into them. If something like this was out three years ago would have gone for it instead. https://radtruckstraps.com/
Packers Fan
Paul
2024 Ford F-150 King Ranch, 2012 F-150 Platinum
Buyer2021
central TX
retired!
Gotta say that all of these plate-mounted ratchet straps look like a PITA to me, really lacking in versatility.
Give me a variety of tie-down points and good-old loose straps with the ratchet mechanism ~12~15" from the hook so it's accessible in a wide range to situations / angles of pull. Absolutely versatile for handling most any load.
If you really use your truck to tote stuff there's lotsa situations where having the ratchet lever down on the bedside would be a PITA; and situations where diagonal pull can be very useful. I'd also much rather my straps not be out and exposed to weather / UV when not in use.
Just one opinion from a long-time pickup owner who actually uses their truck to haul everything under the sun.
Pelican
2024 F-150 Lariat (502A) Supercrew POWERBOOST
Financial Management
Thanks everyone. I just wasn’t sure if I needed something or not. Seems odd that I need to buy extra pieces to utilize what ford installed from the factory. Why wouldn’t they just install something that could be used out the gate? Or can I technically use the ones I have if needed but the aftermarket items everyone is mentioning just adds more functionality?
The items mention by "PackersFan" came with my 2021 Lariat. It may be worthwhile to look under your seats and elsewhere inside the truck before purchasing. Congratulations on your purchase. I hope you enjoy your new ride.
Brandon8
Brandon
Maryland
nurse practitioner
Appreciate it! Enjoying it so far. I looked briefly this afternoon and didn't see anything. Unless I am missing some secret storage compartment lol The passenger side is just the battery under the seat and then the other side I have already filled up. I don't believe anything is in my lockable storage option as well as it is closed own.
mxwrk
Max
Huntington Beach
2022 Lariat Powerboost
I have 4 amazon no name brand boxlink style things, If you pay shipping they're free to you. I replaced them with 4 E track rings from harbor freight
