@Txmade No. You are thinking of Turn signal views. The 50/50 image posted above isn’t exactly the same. That’s more for backing a trailer. See below for the actual 50/50. Same concept but works in forward/drive.Don’t you have to have a trailer attached?
I would like this. What do you mean depending on your existing values at asterisk? What values should it be to enable this?Depending on your exising values at the asterisk.
When you go into forscan to make your changes, look at the forscan spreadsheet for what the values mean. Most lines of code in your as-built cover multiple things.I would like this. What do you mean depending on your existing values at asterisk? What values should it be to enable this?
