Rear camera button stopped working
Ford Motor Company
Official Ford Account
Ford
Dearborn
My 2021 has the same issue with the dash button. I did the latest update 29 July 2024. My F150 only has 25,600 miles. My local Ford dealer to said if the module needs an update they may need to charge me. I have asked them about checking my vehicle to see if they can enable the window down feature using hand remote. The maintenance supervisor told my service advisor they do not use the FORSCAN software. I assume I will just do without. The rear camera works fine.
Hi there! If you'd like to send us a message with your VIN and your local Ford dealer, I can see how I can assist on my end.
pedalquickly
Birmingham Alabama
2021 F150 Lariat
Do you know which software version you were updated to? I'm on 23159 Rev 915 and my camera button doesn't work either.
SilverSpur
Tony
Joplin Mo
2021 F150 XLT, 08 Charger RT, 24 Santa Fe Hybrid
My VIN is as follows: 1FTEW1EP7MKD01598. Hope this helps.
You have to PM them and they will just tell you to go to dealer.
If you are past your warranty then you'll most likely be charged by dealer to fix the camera or do updates. Looks like you are updated on software by what you posted. Possibly you have a hardware issue. Do you see anything with camera button or nothing at all?
SilverSpur
Tony
Joplin Mo
Forgot the local Ford dealership, Its Frank Fletcher Ford on Turkey Creek Rd, Joplin, Mo 64801
SilverSpur
Tony
Joplin Mo
Bryan Simon
Bryan
San Antonio, Texas
Maintenance
okay then.
Something Ford does to your vehicle while you are sleeping kills one of the features the truck was born with. Now, they want to charge you to put it back??That sounds a bit like a kidnapping/hostage/extorsion issue to me..
can this be fixed with ForScan?
SilverSpur
Tony
Joplin Mo
My VIN is as follows: 1FTEW1EP7MKD01598. The local Ford Dealer is: Frank Fletcher Ford on Turkey Creek Rd, Joplin, Mo 64801
Thank you
SilverSpur
Tony
Joplin Mo
The button doesn't operate at all. It used to when stopped or below 15 mph.
SilverSpur
Tony
Joplin Mo
I am having my 2021 F150 rear camera looked at next week. It quit working last year. I handed the service advisor the TSB covering OTA and non 360 rear camera button inop. Will see what happens.
Do you have FORScan? All you need to do it make one change:
706-02-02
xxxF xxxx xx--
You have a 0 there now, so cameras in motion are disabled.
Ford F-150 Rear camera button stopped working 1727369519654-rd
Dave79
Dave
Illinois
2021 XLT 3.5EB
706-02-02
xxxF xxxx xx--
It sounds like @SilverSpur is experiencing the same issue I am, where the camera button is completely inoperable even when parked/not moving. It's a software bug that is fixed in one of the newer software versions. My truck doesn't seem to want to update OTA so I've been stuck with the issue.
FWIW, I tried enabling the cameras at speed in FORscan like you mentioned above. The result was that when the truck is moving fast, the camera button now works, but it will only show the straight down hitch view. The icons for the other views don't do anything when clicked. However, when stopped or moving slowly, the button still doesn't work at all.
I'm certainly interested to hear what SilverSpur finds out from the dealer.
Oh, I misread the issue. I see what you're saying now that I re-read it.
