Latest software update
Bobcatou
Bryan
Port Townsend, WA
Website
listentothewindmedia.com
'24 Lariat, (Carbonized Gray Metallic)
Interesting. I would never think the transfer case module would be a drain on the battery.
Ford F-150 Latest software update 1747843949991-wc
Porpoise Hork
Bret
IT Sys Admin
Just an update to adjust how long the module stays active after the main power is switched off by the sounds of it. You can test it yourself if you have an amp meter by checking the power draw on the 12v battery cable after you turn the truck off. It'll pull a surprisingly high amount of power for up to 60 minutes after key off.
