I used to work in UPS as a Test Engineer, but much larger units i.e. 750KVA plus. The rectify utility AC-to DC battery bus - back to AC for loads process usually produced a dirtier wave. And consider the load switching may be causing noise on the source. Really, you have to see it to know if it cleans it. O-Scope time.@HammaMan I’m certainly no expert and very capable of getting things wrong. I’m currently using pure sine wave UPS units for the better electronics.
Something like this:
I do have an O-scope. I’m thinking my non inverter generator gets even trashier when the 4.5 ton compressor kicks on. I use a MicroAire easy start which helps but I bet the frequency and voltage struggle momentarily lol. I’ll see if I can capture itI used to work in UPS as a Test Engineer, but much larger units i.e. 750KVA plus. The rectify utility AC-to DC battery bus - back to AC for loads process usually produced a dirtier wave. And consider the load switching may be causing noise on the source. Really, you have to see it to know if it cleans it. O-Scope time.
That’s how mine works as well. I don’t believe there is a work around.I am having a similar issue. When I have the 50A transfer panel supply breaker in the main panel turned on when I power the generator I get power shown on the orange panel light, but the generator GFCI trips out when I hit the transfer button. This is with all the transfer panel breakers turned off.
If I turn off the 50A supply breaker in the main panel the transfer occurs properly.
After I have the generator supplying power to the panel, I can turn the 50A supply breaker in the main panel back on and things continue to run properly with the green utility light now illuminated. When I press the transfer button to go back to utility power the transfer happens properly, but the generator GFCI trips out again.
I installed the Generac 9854 according to the instructions. I moved all the neutrals, and I do not have a connection between the N and G bus bar in the transfer switch panel. I have the ground and the neutral cables from the individual transfer switch bus bars going to the main panel on separate cables to the G/N bus bar. All my circuit grounds are still wired to my main panel, I only moved the hot and neutral wires.
I do not have any additional grounding rods added, I depend on ground in the cable connector to connect back to my main panel ground system.
Has anyone had a similar experience, and how was it resolved?
Another option instead of the transfer switch.
I had one of those installed in my panel. It worked well except the Truck's Ground Fault Sensor detects the panel's neutral ground bond and shuts down its generator. If you cannot open up that neutral ground bonding, you cannot run the Truck's generator on the house. At least until Ford gets around their refusal to remove or deactivate the Truck's programming that shuts down the generator when it senses the house's bond.
