2.4 Specifications for Transfer Switch
tottendan
2023 Lariat F150 Powerboost
I got a quote to install a 4-circuit manual generator transfer panel with 20 amp inlet. According to the electrician they asked if the 2.4 requires a lifted neutral for the powerboost to work? I am not an electrician and figured this awesome community could help.
It's subject to all of the same things the 7.2kW system is, and can be bypassed with a version of the dogbone which is easier because it's 120v parts.
Only the 2kW ICE specific unit features an unbonded ground.
Ask for a quote on a 30a generator interlock back feed setup as well. You can upgrade your 2.4 to a 7.2 for about $1k if you desire. The 2.4 can be sold for an unknown amount of $ as they are on ebay.
tottendan
tottendan
Wait - I can upgrade my 2.4 to the 7.2 in the back of the truck? I read many threads that eluded to that but never got confirmation.
dafish
Midwest US
22 F-150 PB KR SCREW, '18 Lariat SCREW
Mostly retired IT Pro - Cyber-IPT
I suggest wiring your house assuming so. Ford says you can't. We'll see.
I'm going to use mine as a guinee pig and then we'll know. Going to do some crude parallel generator tests first, and none of that till we get a little warmer.
Yes, you need part numbers...
MU5Z19A464L (formerly MU5Z19A464C) (on ebay for $170)
ML3Z14G649D (formerly ML3Z14G649B) (Make offer on used ebay parts ~$550est)
REDAG98
Red
Austin
2021 Ford F-150 Lariat FX4 PowerBoost
Regardless of whether you upgrade to the 7.2kW or not, I would ask the electrician to install a 30A inlet at a minimum. You might even ask about 50A as well. Either would be a significant upgrade from 20A and be much more future proof should you ever upgrade, buy a standalone genset, etc.
Oakstone
Victoria, BC Canada
22 F-150 PB XLT 302A
Are there any changes via Forscan required to upgrade or do you just swap out the parts and bam?
Only for monitoring in the APIM
Oakstone
Victoria, BC Canada
Sounds interesting. It’s one piece of the puzzle that I’ve regretted not including in my build. I figured 2.4 would be fine and it has helped me repeatedly with my travel trailer and home, but being able to run the A/C or a space heater would be cool.
How involved is the actual part swap?
