PowerBoost inspired hybrid house
fwunder
fwunder
fred
NJ
2023 F150 XLT 302A Sport 7.2Kw
So the dogbone-with-ground-cut trick doesn't work here? Any idea what specifically trips it in that case, and whether that's unique to Victron or would also apply to e.g. Gen Input on an EG4?
Yes, a dogbone without ground would work. I was referring to using a grounded feed to the Quattro from the Powerboost will not. Interestingly, it appears using the EG4 chargverter does not require any modification.
Mszczewski
Milwaukee, WI
21 F-150 Lariat Powerboost
Are there any updates on the install/build progress?
fwunder
fwunder
fred
NJ
Thanks for asking. I built out cement board wall for inverters and other equipment. Been waiting on local electrician to install ( permitted ) sub-panel and interlock. Should be any day now. Final proposed equipment layout below.
Ford F-150 PowerBoost inspired hybrid house wall-final-v2
ESG406
Ed
Union City PA
21F150 Hyb, 15ExpEL 2 '06 Esc Hyb 99&01elect Rngrs
I really enjoyed reading all these posts. They bring back some very fond memories of motorhoming travels and my wife and I living off-grid in our Prevost coach from late 1980s through mid 2000s. If anyone wants to see how my alternative energy system worked back then, it is documented on our webpage http://rvtechstop.com . There is a page about our system and several articles about alternative energy on the "articles" page. You might also be entertained by the Powerpoint about Miss Maxi, an H345 Prevost coach I cut apart to create a full-body slide.
gb7FRz26
North Texas
2021 F150 XLT SuperCrew Short Bed
Thanks for asking. I built out cement board wall for inverters and other equipment. ....
Those EG4 ChargeVerters are a game changer. Maybe make yourself an L14-30R to regular 120v 15A (NEMA 5-15P I guess technically) dogbone and if you ever need to feed the ChargeVerter from a 120v generator, you've already got the adapter - they'll work off 120VAC at half the output but you can tune it down to 25A (@56V) or whatever max the gen supports. Flexible!
MomaxLand
NC
2024 F150 XLT 4x4 SCREW 5.5
Awesome, thanks. I've been considering a very similar setup, but in semi-portable form: an EG4 12000XP inverter + their indoor wallmount battery attached to a 1000lb-rated handtruck. Main use is to power workshop shed, charged with small solar array. But can (carefully) wheel it to garage and have it power house via 50A inlet, charged by Powerboost, at least when HVAC is needed. If HVAC not needed, then will run house directly off Powerboost.
fwunder
fwunder
fred
NJ
Yes! I have two other generators besides the the Powerboost. The Chargeverter really provides a lot of flexibility, including "dirty" power. Should be and probably will be built into future inverters.
I am real curious to see how fast the Powerboost will charge my battery bank. I am guessing less than three hours to charge my ~15kWh battery bank and about 3 days running my critical circuits from battery bank. Will be fun!
Kodiak
A good experiment for you, if you have the time and are looking for optimalization data, would be to charge the 15kw pack from empty to full on full charge from the PB. That would probably have the PB running full time. Then try it with a charge of under 3.5kw so that the truck can cycle with the on-off feature.
Although it will take more time to fully charge, the on-off cycling may prove the most cost effective way (less gas) of charging. Maybe not but it would be nice to see as the on-off cycling for the PPOB is a gas saving extremely efficient way of using the PPOB.
fwunder
fwunder
fred
NJ
It will be interesting. Going by Ford specs, the ProPower will put out 7.2 kW for ~32 hours with a full 30 gallon tank. So that's 230.4 kWh available or ~0.13 gal/kWh, right?** I will have ~15 kWh battery bank, so a full charge will, theoretically, consume ~2 gallons. If I get three days using 2 gallons of gas running my critical circuits, I will be thrilled!
** I did a bunch of tests last year running my AC and heat in my travel trailer and measured ~0.2 gal/kWh at much less than 7.2 kW.
fwunder
fwunder
fred
NJ
This is the latest revision of the plan for any who may be interested. Yes, I know it's a lot of blue. I like blue.
Ford F-150 PowerBoost inspired hybrid house backup-v5-to-scal
Kodiak
Yes I saw that and saw the same or similar results from others too. I think the key is to keep it at <3200w or so to keep that cycling feature. That what will keep the gas consumption to .2 - .25 gal per hour.
If that holds true then you could run that PPOB full blast for a 2 hour charge for 2 gallons or a 5 hour charge for just over a gallon.
Davexxxx
MO
That matches exactly with my experience.
We ran the camper AC for 12hrs. on ~3.5ga.
Gros Ventre
Western Wyoming
From this you would have about 4 days of fuel in the tank. When I had to go on a generator, in order to stretch fuel I had to run it 2 hours in the morning, 1 hour around noon and 3 hours in the evening. across 10 days. From this I infer one might make a full tank go nearly a month. :)
fwunder
fwunder
fred
NJ
While I wait for my pallet of toys to arrive via FedEx Freight ( tomorrow ), Current Connected just posted this video which explains why there is no ground fault error when using the PB and EG4 ChargeVerter to charge off-grid battery bank.
