Spiffy
- #16
So the end of the story is I got the truck running with the help of Jesse. I think contributed issues was a low charge in the battery even though it showed 12.5 in fdrs.
I had a big charger that outputs. Trickle, 10amps, 20amps , 40amps and 50amps starting.. I had it set to 20amps all day but after using a meter I found it was only putting out 12.1 volts at 20amps. When I moved it to 40amps it output 13.5volts. I let it charge all night. When returning this morning the voltage showing in fdrs was 15.2v
Jesse logged in and did some things and the truck started. Yay!!
Also the apim updat finally finished.
All that's left is getting that dam heat exchanger issue fixed. That's going to be a month.
I'm out of fdrs and only have the temp display change to do in forscan.
One thing I'm super worried about is while in fdrs I saw that the truck logs everything I do .
I wonder if a fird technician will see that I had over 50 things I did yesterday. As a matter of fact there is a log of all my messing around going back months.
Is that going to be a issue with warranty?
But I want to shout out to Jesse. I really appreciate his help.
