Powertrain Malfunction Reduced Power - again/still
RicD
Ric
Mammoth Lakes, CA
2021 LeadFoot F150 XLT CrewCab PowerBoost 6.5
Geek
OK - 2021 PB XLT 4WD, Max tow, 36749miles. of course. Powertrain Malfunction, Reduced power. I have been getting this warning a lot in the past year but now it is constant. I have brought it in for service for this multiple times with no fix. dealer is 5hr drive away.
DTCs in FORscan
P0505 - Idle Control System
P2C43 - Battery Isolation/Voltage Stabilization Control Circuit
U061E - Lost communication with Battery Isolation/Voltage Stabilization Control Module.
Rented a mongoose a bit ago and updated everything. Error persisted.
Purchased a 14ah battery for under the rear seat https://www.amazon.com/gp/product/B...ZptuRYHAbuKp-pKg5M_aem_eoiy3XQ-H0VY2elcdSOp9g
new main 12v
https://www.amazon.com/gp/product/B0CBQ31KYP/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
and a new "aux battery isolator"?
https://parts.ford.com/shop/en/us/e...e-35l-(fuses)-p-ml3z14526b#/partMatched?pdp=y
Thanks to user tcp for the info in this thread.
https://www.f150gen14.com/forum/thr...duced-power-p2c44-12v-aux-battery.6019/page-2
Any thoughts? should this take care of the P0505 also? Thanks all!
You don't need a mongoose to read codes. Start w/ the 12v AGM, factory are notorious garbage. Those codes however do sound like it's the isolator itself. That's technically a unique hybrid component and should be covered under the 8yr warranty for "unique hybrid components" which is an ambiguous term, but the isolator is only found in the hybrid. Ford could argue it in court but the judge wouldn't let them wiggle out of an ambiguous but obvious term. Granted it takes about 5 minutes to swap it out and your time and avoiding the dealers ignorance may be worth the $80 part cost.
Did you verify wiring to the isolator? There's already been a failure with one that's shown up on the forum.
whitetail1965
crosby texas
2024 F 150 4x4 6 cylinders
truck driver
I am having same issue with only 1500 miles on new truck.
RicD
Ric
Mammoth Lakes, CA
Geek
Yeah I probably should have done a visual inspection first.....This was a rodent. The 4 wires from wiring harness were all chewed up and disconnected. White/orange, White/green, Brown/purple and light blue. From wiring harness to isolator. Soldered in new pieces of wire, put a new loom on. The rodent had used the battery blanket as a bed. I replaced the isolator since i had been having issues previously with powertrain malfunction after 60+ miles of driving. Have not yet received the batteries but i ordered an h8 and apparently that wont work in the PB. I removed the blanket and dont plan on replacing it
RicD
Ric
Mammoth Lakes, CA
Geek
Only DTCs that remain are for the rear speakers. I have replaced all of the speakers and wiring to an amp so ignoring that. I have a drive coming up soon so i will make sure and bring the cable and forscan.
BTW i used the mongoose to run updates on everything so i didnt have to have the dealer do that as a primary measure to diagnose. I just use a standard USB ODBC II connector for forscan. Definitely worth doing things myself if it is mostly that easy. I have a 5 hr drive to dealer then wait and drive back. Not a fun day.
The H8 batt will fit if you're okay with leaving the isolator floating.
RicD
Ric
Mammoth Lakes, CA
Geek
well regarding the issues listed here, this was a rodent issue. I still am having issues with popping a Powertrain Malfunction after driving a long distance. DTC P06EF-00-AF and P06EF-00-6D and P06EF-00-2F. I am going to start a different thread since the rodent issue is resolved. Thanks all!
patmulligan99
pat
massachusetts
f150 XLT 3.5 powerboost
Attorney
I was getting the P0A1e code. Prior owner had it. Battery test failed dealer replaced battery. 10k later I’m getting it. Battery test passed, all connections passed. PINPOINT told them to replace the BISG.
Jmitchelltfo
Jeremy
Ozarks
2021 King Ranch PB
Range Ops
Do you happen to have any pictures of the finished product in a powerboost? I’m shopping for batteries and only want to buy them once (especially since I’m spending the money instead of going through the warranty).
I still have my original H7 in that's nearly 3 years old. I didn't take any pics of the isolator when I pulled it out as it was very simple.
