I almost killed my engine!
thiggins
Timothy
Saluda nc
24 Fx4 Xlt
Retarded
Been using fumoto valves on all my vehicles for decades . I even have one on my airplane. Everything in life has risks, but they work great and I trust them (obviously). That was probably a damaged or defective one. Have them replace it. You guys that poo poo everything...🤦🏼‍♂️
Using the old plug risks stripping the pan over and over, plus you gotta replace that stupid gasket very often. Not worth it.
McStabby
Andy
West Central Illinios
2021 F150 Lariat Powerboost
Retired Construction Laborer
Rossi6998
Surprise, AZ
2023 F-150 Tremor, 2024 F-150 XLT
You can do what I did... Instead of buying a $40 drain plug, you can buy a $4,000 car lift for your garage... (Kidding - Sort of) :). Makes oil changes really easy. Glad things worked out for you...
fmdog44
steve
2012 F150 XL
I was doing an oil change yesterday and decided to add the Fumoto Oil Drain Plug Valve. I must have drop the plug or something because when I inserted the plug, the stem broke off. Trust me, I wasn't twisting it that hard. Luckily my brother had a tool that could unscrew the stem without breaking it or leaving it in the pan, so all is good, but quite a few cuss words came out of my mouth after it happened. I put the original drain plug in and plan to keep it from now on.
I do fine it strange that brass was used for that valve, being a softer metal.
No harm, no foul.
It is until now unheard of for anyone to curse while working on the rides especially when something breaks.
fmdog44
steve
2012 F150 XL
My brother bought a small home with a large pit in the garage floor. I told him to rent it out by the hour or half day, etc.
Trainmaster
Eddie
Rockaway Beach NY
2023 Expedition; 2008 Expedition; 2010 Explorer; 1967 Econoline Pickup
Railroad Trainmaster
We've used these on the fleets. American made, not Chinese and appear to address all the valve problems. Not cheap though. You get what you pay for.
https://nospillsystems.com/
Old Hat
IL
On my first F-150 oil change I installed the Ronin drain plug. I like it and consider it unlikely to ever fail in any manner with proper care. That said, I would not trust a Jiffy Lube to not break it; but then I don't trust anyone to work on my vehicles if I can do it myself.
Johnny Tremor
Lawless West
2022 F150 Tremor
I have a Fumoto valve on my f150 and one on my 4Runner for 10+ years before that with lots of off road miles--never a problem. Are there any verifiable Fumoto valve failures? I have not heard of any. I appreciate that it is a personal preference on whether to use one, and I would not use them on anything without a skidplate. But why all the hate on Fumoto valves?
If only there was a tool to make removing the 3.5 EB oil filter as clean and simple.
Dougpaw57
Doug
Olympia, WA
2025 F-150 Platinum Plus, 2014 Porsche 911 Carrera S
I'm also considering vandals. The same tweeker that crawls under your truck for your CAT, might decide to have a little fun with your drain plug.
Trainmaster
Eddie
Rockaway Beach NY
I'm afraid of Fumoto valves. But I've honestly never heard a first-person account of a problem. I believe they are made in Japan.
gb7FRz26
North Texas
2021 F150 XLT SuperCrew Short Bed
So I guess you're just lucky then.
It's a reputable Japanese company making these valves for quick oil changes since 1976, it's not lucky that it hasn't failed for him, it's engineered well. It's like a little lock on a bathroom stall, You have to make two separate motions to get it to turn.
That said, in the past few years there seem to be more of them sheering off during install, like what happened to OP.
Dougpaw57
Doug
Olympia, WA
If you put something that easy to F with, somebody will F with it. Unlikely that anyone will F with a drain plug that requires tools to open.
gb7FRz26
North Texas
Well that's talking about two different things isn't it. Mechanical failure versus random people crawling under your vehicles to wreak havoc, cutting brake lines and sticking bananas in the tailpipe.
sporkfed
TN
2024 F-150 XL RCSB
Toyota is a reputable Japanese company, yet Tundra engines are blowing up left and right.
Unfortunately, I'm not sure being a Japanese company means as much as it used to.
