Factory Wheels with Aftermarket Tire Thread
nomarhits400
Bellbrook, Ohio
2023 F150 Poweboost
Analytical Chemist
Hello, I just picked up my 2023 XLT with 5.0, FX4, and BAP. I do not plan to install a level or lift. I would like to run a LT275 /65 R20 tire on my stock BAP rim. Is anyone else running this set up? I want to find out if there would be any rubbing issues prior to purchasing the tires! Thank you and I appreciate your input.
I’m running that setup- so are plenty of other guys on here- Nitto Recons 275/65/20’s. I actually have a slight rub at full right lock when backing up- but it’s very minor.
Completely stock suspension otherwise:
Ford F-150 Factory Wheels with Aftermarket Tire Thread IMG_3961
Ford F-150 Factory Wheels with Aftermarket Tire Thread IMG_3951
Ford F-150 Factory Wheels with Aftermarket Tire Thread IMG_3568
nrmedic
NC
2022 F150 PowerBoost 302A; 2023 Tacoma TRD Pro
All I have of the back. I traded this rig in a while back for a Powerboost.
Ford F-150 Factory Wheels with Aftermarket Tire Thread IMG_2395
Ford F-150 Factory Wheels with Aftermarket Tire Thread IMG_2394
Ford F-150 Factory Wheels with Aftermarket Tire Thread IMG_2393
Maceman
Mace
Atlanta
2022 F150 Lariat
Looks great. I have the same color in a 2022 Powerboost. Think I may go with that same setup but wass contemplating the Fox 2.0's. What did you put on your PB? Any pics?
nrmedic
NC
Ford Performance Bilstein level is on order.
fluffernutter
NJ
2022 Ford F-150 Lariat PB
Got a set of stock size BFG ko2's (275/60/R20), no plans for leveling since I tow.
Love the look! Hopefully no more slipping in wet grass.
Ford F-150 Factory Wheels with Aftermarket Tire Thread IMG_9110
Ford F-150 Factory Wheels with Aftermarket Tire Thread IMG_9112
Ford F-150 Factory Wheels with Aftermarket Tire Thread IMG_9113
Was working on a deck in my backyard and this happened with the stockers:
Ford F-150 Factory Wheels with Aftermarket Tire Thread IMG_9114
It's great having the wife recommend a tire upgrade!! (hint for those who can't get approval, just tear the crap out of your own yard first!).
I like how just a tire change improves the look so much. :)
Thought about trying to go up a size but not confident with the tight space on front. I have no interest in level either.
fluffernutter
NJ
Mine has some very light rubbing with full lock, it hits the wheel well liners ever so slightly and only when completely backing into a spot. Could imagine how much worse it would be with upsizing
**Edit: I did drill a small hole in the bottom of the wheel well liner and used a zip tie to pin it back. It still rubs, but must be doing on the inside and not the outside. I tow my travel trailer, so I don't want to raise the front. So guess I'll just live with this. But a word to the wise for anyone looking to get the same size ko2 (for me it was lt275/60/r20) when replacing stock, there may be rubbing without any front lift. I also am having a hell of a time getting these balanced. Will have to take it to a place with a road force balancer (mainly the dealers around me have them), so when I go in for the e-brake recall, I'll have them balance all 4 to avoid shimmy at highway speeds.
Same issue with stock size aggressive tread on my old 2011. Full lock would rub the front wheel liner but never did any real damage.
Gallagher023
New Jersey
F-150 LARIAT 501A
I have a 2022 5.0 SCREW with the 18" Sport Wheels I want to keep it stock I dont have a lift/level what are the largest tires I can put on without rubbing?
vinnie45acp
Vince
Virginia, USA
2022 Ford F150 Lariat Sport/Sport appearance Package/502A
Logistics
275 60 20
Mickey Thompson Baja Boss
You only Drop Shackled this? You did not take out the rear blocks? I am looking at doing something similar, maybe adding rear sway bar and rear shocks at the same time to improve ride.
How much rack do you still have?
How does it ride, any vibrations at all at any speed?
