BarryT82
The software downloaded using the link. Thanks.Try this link to download the VCI software. https://www.motorcraftservice.com/d...ryId=276&from=helm&language=EN-US&country=USA
WHats your vinI tried my first apim update yesterday using the fdrs and mongoose. FDRS says everything passed and is complete but I'm noticing no changes and have the same sync version still. Any ideas what I should do? Thanks.
Your going to have to give me some info and or backstory. You have 4 serial numbers different serial numbers showing for the APIM.1FTFW1ED2MFC02951
THANKS
First Apim I had the greyed out automatic updates issue a lot of folks had. The dealership replace it. Then with my second Apim it would toggle back to automatic updates and I tried waiting months and months for an update with nothing going on. Brought it back in, the dealer tried to update it and replaced it again a month or so ago. So hear I am trying to do it myself. Thanks again.Your going to have to give me some info and or backstory. You have 4 serial numbers different serial numbers showing for the APIM.
Ok. they replaced it with a 2022 APIM and that can be problematic.First Apim I had the greyed out automatic updates issue a lot of folks had. The dealership replace it. Then with my second Apim it would toggle back to automatic updates and I tried waiting months and months for an update with nothing going on. Brought it back in, the dealer tried to update it and replaced it again a month or so ago. So hear I am trying to do it myself. Thanks again.
yes my second apim had a newer version ( 21281 rev 244 ) then my current one. Currently I'm at the 21146 rev 145Ok. they replaced it with a 2022 APIM and that can be problematic.
What is the current version showing when you go to general/ settings / about sync
Most of the time when they install the 2022 apim there should be a 16GB update to roll the apim back all the way to the version before 21146.
20310 I believe is the version then from there you go up. THe version you were at was probably 22082 or 22025
It wont go anyfurther until the gateway update is complete. For whatever reason the gateway is not showing as an update.yes my second apim had a newer version ( 21281 rev 244 ) then my current one. Currently I'm at the 21146 rev 145
Appreciate the help thanks for your time.It wont go anyfurther until the gateway update is complete. For whatever reason the gateway is not showing as an update.
I cant look right now to see the issue the systems are down for maintenance
It's actually under the hood latch. ?A little off topic... Where would I find the switch that tells the truck the hood is closed. I have an update ...1007... And it says it can take upto 38 minutes...want to have my charger connected but the update needs the hood closed. I want to bypass the switch and make the truck think the hood is closed.
1007 is a quick update, unless your battery is very low it should be fine. It took my Lariat PB about 15 min.A little off topic... Where would I find the switch that tells the truck the hood is closed. I have an update ...1007... And it says it can take upto 38 minutes...want to have my charger connected but the update needs the hood closed. I want to bypass the switch and make the truck think the hood is closed.
