it appears it was..ha but not 100% if I enabled it as I was meesing with my settings. I had to reactivate my fordpass app.Check to see if your weather is working is the fastest way. In nav the top button with the three lines. Once in select weather see if it loads
You leave the USB in the truck?Good Day, I updated my gateway module today and it said it was successful, then I proceeded to up date the APIM and that said it was successful and then it went into the FDRS double check and it said it was having a probelm communicating with the module and didn't complete through FDRS... now I am having problems getting in with FDRS saying it can't see my VIN and forscan is showing me this. Everything seems to function as far as I can tell.
I left it in until it said remove USB and then I did.You leave the USB in the truck?
make sure you have the ignition turned on, engine not running.Good Day, I updated my gateway module today and it said it was successful, then I proceeded to up date the APIM and that said it was successful and then it went into the FDRS double check and it said it was having a probelm communicating with the module and didn't complete through FDRS... now I am having problems getting in with FDRS saying it can't see my VIN and forscan is showing me this. Everything seems to function as far as I can tell.
I am starting to wonder if it is my mongoose or laptop.... I am digging into it a little more on that end since neither of them seem to communicate with the vehicle right now.make sure you have the ignition turned on, engine not running.
This is what I received from amazon when I ordered mongoose plus for fordLet me know if the mongoose doenst rectify it.. FDRS is EXTREMELY sesitive to the pass through device.
I can get it fixed regardless. Let me know
That doesn’t looks like what most of us have, can you also post a pic of the packaging?This is what I received from amazon when I ordered mongoose plus for ford
That doesn't look like any mongoose I've seenThis is what I received from amazon when I ordered mongoose plus for ford
didn’t come with any packaging, just a plastic bag with no info on product, the plastic around the ford sticker on it is scratched up tooThat doesn’t looks like what most of us have, can you also post a pic of the packaging?
I’d get Amazon processing a return asapdidn’t come with any packaging, just a plastic bag with no info on product, the plastic around the cord sticker on it is scratched up too
Returning it now, ordered anotherI’d get Amazon processing a return asap
