farmtruckman
Dubai
2021 F150 Raptor
Finally got around to updating my “stuck” 2021. Took 2 full days, but went off without a hitch.
2 questions I’m left with:
1) Is it normal to have all these modules “not responding”? Is there a procedure to get them to respond?
2) ACM updates run through without any errors, but shows back up every time. I ran it 5 or more times and it’s still there. Not really concerned about it unless I should be. Thanks.
And lastly, I ended on Sync Version 23291 Revision 1049. Do I just have to wait for Ford to put me in line for another update?
These two updates are known to be in a state like this. BCM requires credentials and ACM is known to stick around.
farmtruckman
Dubai
2021 F150 Raptor
On an update spree, doing the APIM now and I downloaded it to the USB. When I insert the USB I get a weird error. Tried with 2 new sticks too formatted as ExFAT. Any pointers till @rugedraw or one of the gurus get online?
Ford F-150 ECU module programming guide using FDRS 1735562578686-nz
Spiffy
Usa
2022 platinum powerboost
:inlove:I'm definitely not a guru. Usually when I first insert the usb a windows file manager screen pops over. Showing the files and directories that are on the drive. That usb i use is specifically for the fdrs porpoise.
Do you have access to another windows computer to try this usb in? Then reformat ExFAT and validation that it's at least 64gb.
Make sure it works on another computer.
If it does but not on your fdrs computer suspect a wonki port
Kanuck
Winnipeg, Manitoba
Retired Electrician
Name the stick a short name like "sync" . What brand of stick are you using? Try a different brand. You can also use a USB -C stick if you have one. Formatted exFat.
farmtruckman
Dubai
2021 F150 Raptor
I named it “USB” - it is a SanDisk stick. Supports both USB A and USB C - have used the same stick to update before.
Spiffy
Usa
It could have failed. Try a different one.
Kanuck
Winnipeg, Manitoba
Retired Electrician
You can also do a complete format and not a quick format. Will take some time but there maybe some issue there.
m_bt54
Bryan
Massachusetts
IT Director
Keep trying different ones till it works. You don’t have to build a new stick with fdrs every time. You can copy/paste the files. I’ve had a couple that worked once or twice that didn’t the next time I tried.
Trucks are finicky w/ USB sticks and that's the typical error I get w/ most of my sticks
breadnbutta
Flawda
2021 F150 Platinum FX4 3.5 EB
Can someone please PM me the values to change in forscan to enable bluecruise 1.4 features? I sent rugedraw a PM yesterday but it doesn't look like he's gotten a chance to respond yet. Thanks!
m_bt54
Bryan
Massachusetts
IT Director
I’ll have it over to you in a minute
breadnbutta
Flawda
Another dumb question.. I need to have the truck on in accessory mode the entire time while performing the updates right?
m_bt54
Bryan
Massachusetts
IT Director
Yes. Start with it that way and it will walk you through when to turn it on/off and in certain cases do it for you.
Sig Oris
Western Maine
MY 23 F150 Crew Cab Lariat w/3.5L Powerboost
Retired Engineer
Maybe asked before and my apologies in advance to Post Patrol.
Can all or some of the updates available via FDRS be downloaded to a USB stick to install thereby negating the need for the Mongoose Thingy?
