Ajzride
Automation
I just want an APIM update. My XM Presets have always been flakey, but lately they have been resetting back to default every 2-3 days. Gets old having to set them up over and over and over again.
RickBullotta
Rick
Pennsylvania
2021 F-150 Lariat Powerboost
I can’t say it doesn't itch a little.
It does. My brain keeps telling me that a Powerboost specific PCM update can ONLY be a response by Ford to address Powerboost specific remedies for known issues.
But the other part of my brain says that if Ford won't divulge exactly what this PCM update is intended to address, then I'm only guessing/tempting that it won't affect my truck in any way, even though I have no personal complaints at all.
I've been fortunate to have gotten what so far has been a trouble free fully equipped (no constraint other than park assist) highly optioned truck. While I AM looking forward to the potential of further refined Lane Keeping/Adaptive Cruise performance (with Bluecruise 1.2) , I otherwise can't think of a single update of any kind that I desire.
Having said all that, if Ford stated this PCM update enables EV in Sport Mode? I'd pay $500 for 2 hours FDRS access and dance a jig on YouTube for all the world to see.
This is totally anecdotal, but it "feels" like smoother transitions in and out of electric mode after the update and smoother off the line. Could be just placebo effect too. Given that there was an ABS update also, I was wondering if the reports of trucks jumping forward on their own were legit and this was a fix to that issue. I guess we'll never know.
JIMFOUNTAIN
Jim
Austin, Tx
2021 F150 SCREW PB 6.5' 701A
This is totally anecdotal, but it "feels" like smoother transitions in and out of electric mode after the update and smoother off the line. Could be just placebo effect too. Given that there was an ABS update also, I was wondering if the reports of trucks jumping forward on their own were legit and this was a fix to that issue. I guess we'll never now.
And now you are just baiting @Snakebitten !!!
imnuts
Dirty Jerz
'21 502A Powerboost 4×4
Facilities Engineer
This is just a guess, but I think the reason the Powerboost tends to get the PCM/ABS tandem for updates is because of regenerative braking.
Airborne_Ape
Chad
Atlantic Canada
2010, 2014, 2017, 2021 F150
Having bricked my truck once with a bad BCM update, I totally get the desire to not f*ck with it!
I’d like to see these forums add little merit badges under our user names; bricked BCM should be one of them. I did it once back in 2017, fun times.
:unsure: ‘Don’t f*uck with it’ should be the title of this thread.:LOL:
Foxtrot150
Houston, TX
2021 302A PB SCrew 6.5
Quick sanity check for my '21 302A PB with Pro Trailer
  • Originally didn't have GWM/APIM/TCU updates (no IPC either)
  • Performed the IPMA update (2.5 hours), then a GWM update appeared
  • Performed the GWM update (about 0.75 hours total)
  • Performed the PCM update (kicking off ABS and SOBDM updates) (about 0.5 hours total)
Network Scan performed between update processes
I now have these remaining - is there a preferred order? Update: I attempted ACM, then did HVAC, DDM, PDM.
  • DDM
  • HVAC
  • PDM
  • BCM
  • ACM [just a woofer install]
What procedures do I need to run (once I update all modules)?
  • Image Processing Module A (IPMA) Alignment procedure
  • IPMA - Pro Trailer Backup Assist Camera Alignment procedure (I don't have 360)
  • DDM/PDM - Power Door Window Initialization (appears optional; only if having issues)
Foxtrot150
Houston, TX
Well I went ahead and updated all modules.
I kicked off the IPMA Alignment procedure - is it possible to cancel it? My laptop must be plugged into power or it will die and it's currently hooked to my garage outlet. And I need to drive a bit before I can find a road with lines on either side.
Update: Pulled the plug on the laptop... I guess I like to live dangerously.
On another note, is there a module I procedure I can do to fix the "Sirius XM is loading..." and "Loading map..." (navigation) issues I'm experiencing? All my previous SXM presets now say SDARS (an APIM soft reset does not help). Here's my post on the issue: https://www.f150gen14.com/forum/threads/issue-siriusxm-loading.18202/
You don't need to do anything but the updates. No reason to do calibration and such unless something changed on your truck. The data it needs is already stored somewhere. If you already started the process though you might need to do it if things don't work now.
I've seen the SDARS thing before and it went away driving around but I've not had long term nav or Sirius issues.
Agavi807
Avi
Maryland
2021 f150 lariat
What's the latest sync 4 version? I had a bad apim and never received an update. Dealer replaced apim and I have been spending hours updating my truck (2021) I've done around 19 updates including 4 apim updates. Wondering how much longer it'll be till I'm up to date. I think it's on revision 711 or something like that
Versions are dated. 22177 is approximately day 177 of 2022.
23031 is current version according to my notes, but I had 5 updates after that to get to equivalent of OTA 4.3.5.
