It’s not stupid. It worked. And if it did then that’s all we want.I accidentally selected the original module IS installed when I ran the PMI. Stupid in hindsight, but the DTC cleared nonetheless and the config completed.
It’s not stupid. It worked. And if it did then that’s all we want. Thank you for sharing as we have learned there are many ways to handle things.I accidentally selected the original module IS installed when I ran the PMI. Stupid in hindsight, but the DTC cleared nonetheless and the config completed.
I was in FDRS today and did not see any updates for IPC, currently ML3T-14C026-BAK (8" Cluster with 5.0 xlt), my Sync software only shows ML3T- , nothing else.So, A note about the IPC update. I have done it now and I have seen the OTA for thee IPC files.
Step one of the update is to install
Target Identifier Current Software # Previous Software # File Size Module: IPC INSTRUMENT PANEL CLUSTER F120 ML3T-14C026-CRC ML3T-14C026-CDL 186.03 MB F188 ML3T-14C026-CPC ML3T-14C026-CCM 1.84 MB
These were installed then there is a second part of the update.
Target Identifier Current Software # Previous Software # File Size Module: IPC INSTRUMENT PANEL CLUSTER F120 MU5T-10F906-FDA ML3T-14C026-CRC 186.03 MB F188 MU5T-10F906-FCA ML3T-14C026-CPC 1.84 MB
Notice the previous files and the new files.
It went from the updated files to the newer files with the new middle part number
I believe everyone should be at the MU5T-10F906-FDA and MU5T-10F906-FCA
There are two steps to the update so PLEASE pay close attention while doing it.
I believe it is safe now. I did mine this morning and it went well. I have a V8. The first step was a USB update. AFTER the selecting the USB was successful it proceeded to the next part and it was CANBUS only it did not give an option. This is where the 10F906 files will be loaded
IF you get a error where is will not configure do NOT Panic. Just let it roll .. you can retry if you want but if you dont it is OK> Just follow it out
You will get a possibly DTC u2100 for initial config not done. This is OK it comes from the config not completing . Do a PMI. Select the original module is NOT installed and follow prompts.
Make sure to pay CLOSE attention to the whole process. Again it is TWO STEPS. The initial step gets you to the CRC and CPC the final is FDA and FCA.
I was able to recover the cluster that was blown and I am side loading the FCA and FDA level now. So if anyone had a issue dont panic it is savable. I had one completely blank! Its back to being fine now
thanks for the heads upHi Ebrou-
I think Jesse's quote is more specified to the 12" clusters. I have the 8" as well in a 5.0L XLT and our versions are the same. ML3T-14C026-BAK
That's correct.Hi Ebrou-
@BHunted1Does anyone know what the 'DATA LABEL="706-29-### covers? It's the only area that some data seems to change daily. Runs from -01 to 201...
Ex:
<DATA LABEL="706-29-01">
<CODE>0A2B</CODE>
<CODE>08E6</CODE>
<CODE>A600</CODE>
Thanks for the encouragement. Got my Nano today with laptop coming. Will get started on my Job 1 Platinum next week!I realize there's some hesitancy with the Nano, but I am now about 18 updates into my Job1 Platinum Powerboost and its a little bumpy at times, but you just keep plowing.
Ford OTA and the dealership would be maddeningly far behind with my truck.
Oh, and there was a TRM trailer module update too. I finally had no DTC when I scanned before I quit for the night.![]()
Perfect Thanks!Yes it will!
I'm in the same boat, just got my nano earlier this week and was going to play around with it this weekend and try my hand at getting everything updated. Was going to hold off but looks like tides are starting to turn again in everyone's favor so may give it a go if I feel like rolling some dice.OK guys, please keep us posted when this update is good to roll with.
I see the TRM update is out to correct the DTC and seems like I have a few other updates to do.
Since I only get the 2-day license want to get the best bang for my buck.
