rugedraw
New? lol Not at all. FDRS is about as stable as my baby momma.Well, that is new. FDRS crashed to desktop.![]()
Now I am curious if I have an APIM update. I am still on 24127.Hmm, this already ran, then it tried to run it again when triggered from second time updating IPMA.
Doesn't seem to be any issues, only thing left is BCM as expected.
Thought I would have more updates than this though.
Today's work:
GWM update
APIM update 24127
PDM update
DDM update
TRM update
TCU update
APIM update 25094
PSCM update
IPMA update
Check if it turns green with the truck running. If there are no codes in the PSCM, you should be good to go.Okay PSCM keeps showing gray now.
Did it break?
Edit: Alive again after closing and reopening FDRS to rescan truck.
Did my usual Forscan as-built backup.
I'll check again later in week to see if more updates appear but looks like I'm done.
Yes. TRON (if broken by an update which apparently happens very easily) needs to be fixed with a service procedure in FDRS under the GWM guided routines.I may have missed it so pardon my ignorance if so. Is there anything that needs to be done related to TRON once these modules are updated? My 25 hasn't received any OTAs and I have a ton of updates I want to do before installing my CCM.
Turned green I think it is fine. All my tire pressure is blank but that should get fixed when I drive again. I don't remember that happening before but it has been over a year since I updated.Check if it turns green with the truck running. If there are no codes in the PSCM, you should be good to go.
Surprised your have a APIM update showing. You have a 2021. I thought APIM updates were blocked. especially for the 2021"s?? he has a 2021 and could not get the audio update to go through and no APIM.Hmm, this already ran, then it tried to run it again when triggered from second time updating IPMA.
Today's work:
GWM update
APIM update 24127
PDM update
DDM update
TRM update
TCU update
APIM update 25094
PSCM update
IPMA update
Not all vehicles have APIM updates blocked. Imo, the fact that they are blocking update for any vehicle is stupid, but I digress.Surprised your have a APIM update showing. You have a 2021. I thought APIM updates were blocked. especially for the 2021"s?? he has a 2021 and could not get the audio update to go through and no APIM.
No. GVMS warnings can be cleared, but you gave to submit the as built data request for each one and wait for Ford engineering to look at it and clear them.Judging by the update Excel file I'm still missing some things.
Is this what people mean by blocked updates?
Well that sucks. Don't have license time for that. Is this related to doing Forscan changes? I don't remember this being an issue in my past update sessions.No. GVMS warnings can be cleared, but you gave to submit the as built data request for each one and wait for Ford engineering to look at it and clear them.
