Battery Charger/tender Question
Borchelt
Tom
Boise, ID
2021 F-150 XLT, Powerboost Hybrid
The manual suggest that you’ll be fine to leave the charger on all the time. For reference, I have a 14 year old optima yellow top battery and charger that I leave on all the time. It’s still reporting 100%.
They make this without amp setting. It will do what it needs to do to charge the battery, up to 5amps. I never cared about charge rate until I got several hundred ah of lithium batteries. Now I’m disappointed with my noco10. All you need to do is make sure it’s set to AGM and it’ll take care of the rest.
greetings to a fellow Idahoan.
I love my NOCO 10...but my battery is only 2 yrs old, Autozone Platinum H7, Your battery is actually 14 years old. Wow...that's a lot of trust in old equipment!
Bunker
Idaho
2022 F 150 Powerboost Lariat
Well, the yellow top is in a 57 Chevy, making it one of the newest parts of the vehicle. It also doesn’t have to run a bunch of computers and such. The biggest draw is probably the 8 track player. 😂
My stock Ford battery made it 38 months before it gave me the “going to sleep” message. I even threw it on the charger every 3-4 months trying to keep it healthy. I should swap it out before the fall turns to winter.
stlgrym3
SoCal
2023 F150 PB Lariat
is 5amp a safe current setting for trickle charging on our F150s?
rr11
Rick
FL
2023 F150, 2005 Jeep TJ, 2003 F250
Retired Fire Fighter
I have a NOCO 10 that is my primary maintainer; however last time I got the low battery message I used the NOCO 5 that I use for mowers and it worked fine. If the battery is very low it will take more time but it raised my charge overnight to full charge,
stlgrym3
SoCal
2023 F150 PB Lariat
Finally got the Genius 5 installed yesterday. Decided to mount next to the 12V battery and routed the extension cord through the front grille. So there’s no way to set the amperage? Genius 5 only charges at 5amp?
Ford F-150 Battery Charger/tender Question IMG_0410
Ford F-150 Battery Charger/tender Question IMG_0411
Bunker
Idaho
Cool way to mount it!
the noco5 uses a 8 step charge process. It will use what amps and volts it needs to complete the steps to keep the battery in the best health possible. Fixed or flat rate float chargers are sorta old school at this point. I know the noco10 can act as a power supply, but that’s a different story.
FaaWrenchBndr
Denver, IN
‘24 XLT Powerboost
I use a Oko one amp. The module itself plugged into the outlet. All I have is a cord running from the battery to behind the grill.
Ford F-150 Battery Charger/tender Question IMG_6478
Ford F-150 Battery Charger/tender Question IMG_6479
Ford F-150 Battery Charger/tender Question IMG_6480
stlgrym3
SoCal
2023 F150 PB Lariat
Is it safe to connect the Genius 5 to the truck all the time when not driving?
stlgrym3
SoCal
2023 F150 PB Lariat
I noticed the charging LED lights on my Genius 5 were off, the only LED indicator that’s lit is the AGM 12V indicator. But when I reconnect the powercord to the charger again, then it’d go through the charging process ( flashing red, then yellow, and then green). But the next time when i opened the hood and all indicators were off again. When the battery is fully optimized, do all the charging status lights turn off?​
Sojourner
Maryland
2023 F-150 Tremor
Retired Army / Disabled Vet
On my Noco 2D, Noco 5, and Noco 10 the lights get to a pulsing green and then when that last phase finishes it turns and stays solid green. Maybe Noco changed the status LEDs recently (my units are about 2 years old)?
Calson
Monterey CA
If the truck has a parasitic draw problem the battery tender is not going to be able to keep up with the rate of discharge. With my 2022 F-150 the parasitic draw would full drain the H7 battery overnight and so it would have a 0% SOC in the morning when I tried to start the engine.
A low SOC will destroy a starter type battery and I had to replace the one in my truck 3 times in 3 years. I was using a battery tender every night but it was not nearly enough. I would have needed to remove the battery cable each day and attach it when I wanted to drive the truck.
In my 59 years of driving it has only been the Ford BMS that has given me grief.
That's because only Fords have battery issues. Common knowledge.
rr11
Rick
FL
Unless you visit the Jeep forums. With the 2nd "motorcycle" battery buried under the fender, they make Ford 's battery problems seem minor.
stlgrym3
SoCal
2023 F150 PB Lariat
well it's been good and consistent so far. i left it plugged in all the time. once a while i powercycled the Noco just to monitor the status lights in action. it's pretty consistent, whenever i opened the hood, it was flashing green slowly, meaning the battery is at an optimized level, however, i've never seen it at solid green (standby mode). after i powered up the Noco, the status lights went from flashing red to amber back to green. i have to remind my wife everyday make sure to unplug the Noco in case she needs to drive the truck, think i'm starting to get on her nerves LOL
Sojourner
Maryland
2023 F-150 Tremor
6 vehicles (and 1 UTV) all on a Noco 2D. All batteries at least 2 yrs old (some much older). No issues whatsoever with any of the Ford batteries (4) or other brands (the other 3, which includes the UTV). Multiple issues with Ford's batteries on a vehicle I no longer have where I didn't go the Noco 2D (or similar) route.
Bottom line, I'm sold on the Noco 2D solution.
