I don’t see a way to do that. I see lane keeping calibration but not lane centering
Give it a try. Likely need the newest software for the IPMA. That first round was meh
ZekeB
Zeke
2022 F-150 Lariat
I'm just here to say a huge THANK YOU to @superfordman and @Jesse-Infotainment specifically, but also plenty others for the information in this thread!
I just finished adding Adaptive cruise with lane centering to my 22 F-150 Lariat with equipment group 500A after reading this thread and learning from all the work you guys did to figure this out.
Thanks!!! And if you're ever in the Central Mississippi area give me a shout and I'll buy you a steak and a beer! Great stuff!
AntimatterJoe
Joseph
2021 F-150 XLT rwd
Well, today I managed to turn on PSA on my sync screen (forgot to take a picture) from what I’ve read earlier on it was just the one change in the APIM so we’ll see later on if it works.
Also, for any Mac users out there I can confirm that there is a way to run Forscan without using bootcamp or parallels.
johnhbrandon
Colleyville, TX
2022 Lariat, 3.5 Ecoboost, 4X4
IT Manager
Hey ZekeB, sorry I missed out on helping with CoPilot Assist 2.0 on your 22 Lariat. When I got into this thread about a year ago, I was able to add it to my 22 Lariat with the 500a just like you. I haven't read what you had to do, but I had to add the wiring from the CCM up to the IPMA since the wires weren't there. Other than that and getting all the ForScan settings correct, I had very few issues. I've also added auto wipers and bed lights since the 500a trim did not come with those.
ZekeB
Zeke
2022 F-150 Lariat
No worries doc. I didn't post anything until after I was done. I found all the information I needed just reading through the thread. I just posted to thank everybody for sharing all the info.
Same as you, I had to add the wiring from the CCM directly to the IPMA. Ordered connectors and pins and built my own harness. I've done a lot of tinkering in my 47 years and I've been an industrial controls electrician my whole adult life, so I found it to be really easy to do once I found all the information in this thread. I haven't added rain sensing wipers, or bed lights, but I may do those soon. I did add the lighted cupholder, media box light, and glove box lights yesterday. Thanks to @JHForman812 that was even simpler since he makes awesome harnesses that just plug in where needed.
deagle2008
Jordan
BC Canada
Contractor
Trying to figure out a fix for the new problem that the recent updates has caused. Before the updates, I was able to turn on the ACC separately and Lane centering separately but now when I turn on the ACC the lane centering also comes on automatically, than I have to press the lane centering to turn it off. anyone know a way to separate these two functions again.
Sync version 24127
Revision 1270
Sync version 24127
Revision 1270
This is ford forcing BC on to try and sell it. Is what it is
superfordman
Troy
NE CO
2024 Raptor 801A
Precision Ag Guru
Sync version 24127
Revision 1270
Yep, came out with new software a year ago or so and pretty much hard coded in it now to enabled lane keep when you enable cruise as well.
BigBeautyII
Remmington
2024 F-150 screw 5.5 bed 5.0 4x4 stx
Maintenance Engineer
Hi everyone im new to the group 9/30 I picked up my new my24 stx 5.0 screw w/3:73 (so it's ready for the whipple later). It was built 8/24. Anyway I plan to add the ccm, fabricate and run my own harness from ccm to ipma, and replace the entire steering wheel with a leather wrapped with heat and adaptive cruise control buttons pre-installed. I plan to focus on the heated steering wheel later. Currently I want to do the adaptive cruise right away. Has anyone completed this on a 24 yet? Is there enough forscan data available for the 24 to get this done? Is the ccm module the same part# as the 21-23 ford website only lists it for 21-23 currently.
Ford F-150 Adding Co-Pilot Assist 2.0 with Forscan? 20240914_115149
OIF_Veteran04
Joseph
2023 F150 Regular Cab XLT
What is the pin size for the IPMA to pin the missing wires?
Je1279
Jared
Upstate NY
@antho provided the terminals for the IPMA connector on page 13.
ReverendQ
Kevin
SoCal
Website
www.linkedin.com
IYKYK, but feel free to ask if not. :)
Ford F-150 Adding Co-Pilot Assist 2.0 with Forscan? IMG_0003
DamyanReuto4
Damyan
2022 f150
I’ve installed the ccm, and followed all the spreadsheets making sure to figure out the right codes to change for my vehicle. But I can’t seem to get adaptive cruise and lane centering to work. Now my auto high beams don’t work, normal cruise control and lane keep doesn’t work even after trying to calibrate my ccm. Does anyone know what my issue might be? Or perhaps anyone from the Portland OR area be able to look in person for $
Je1279
Jared
Upstate NY
I would suggest reverting all modules to their prior settings. After that, review and reconfirm all of the changes that you made. With this upgrade, there are 15+ required changes in Forscan. If you get any one of them wrong or make the change to the wrong value or position, you will have problems.
