Victorbaars
Victor
Denver
2023 F150 Raptor
So you wheel heats up and the buttons don’t work still? I have to ask and not just assume, you did update all of the required as builts, correct?
The weird thing was that I didn’t have to update anything, when I open SCCM on my Forscan the values were exactly what I needed.
dolsen
KY
2022 Rapid Red 701A
When it asked you to load a profile, did you select one to load or did you tell it to find all modules again?
dolsen
KY
2022 Rapid Red 701A
I’ve load The profile
Don’t load it, make it find the modules again. You’re reloading old saved data on your computer, not what’s in the truck
Once you do this you will have to write your as-builts to the SCCM
Victorbaars
Victor
Denver
2023 F150 Raptor
Do I need to upload factory settings then first?
dolsen
KY
2022 Rapid Red 701A
I don't recall all of the command prompts when running through FORScan, but you need to make sure you do not load a profile. Then (assuming you backed up your factory SCCM) once the modules load, you'll go into the SCCM and "load all AB". Then select the backed up version of your SCCM as-builts. Then from there, make your HSW changes and both the steering wheel buttons and the wheel heat should function as expected. If you did not go through and back up your as-builts, then you could manually type them all in, assuming you have them written down somewhere. Or you can search for them using the motorcraft as-built website. It's pretty tedious doing it that way and introduces a HIGH probability of error
lawduck1
Ryan
Washington
2021 F150 Platinum Powerboost
This is my once/year request to raise money for the upcoming Autism Speaks Walk in my area that I participate in every year. My son has Autism so this is a fundraiser that's near & dear to my heart. If you feel like my FORScan spreadsheets/tutorial have benefitted you in away way and you'd like to donate a few bucks to this cause that's tax deductible then I would really appreciate it.
Autism Speaks Walk Donation Link
Done and BUMP.
Victorbaars
Victor
Denver
2023 F150 Raptor
Just an update on my situation, it’s all working now, I’m not sure if the problem was in BB vs HB clockspring but mostly my process, as @dolsen suggested, I’ve ran all the blocks again, then wrote my original built, turned off the ignition disconnected Forscan, connect it again and run all the blocks, then made all required changes. All the steering wheel buttons immediately start working, the hsw is working too. I haven’t checked the same process with the BB part, so maybe it wasn’ta part but me wasn’t following the process, on frf forum people were able to install BB part in raptors with no issues.
dolsen
KY
2022 Rapid Red 701A
Another member with a 23 raptor HAD TO use the -HB part number. @Jmeo what was your experience?
antho
Anthony
Houston, Texas
2024 Raptor 37
@Victorbaars @dolsen
I havent looked much into what folks are doing for the heated wheel swap but i do know that the SCCM for the raptor has a different strategy file. So just loading asbuilt onto a BB may not work right. You probably have to flash the proper files to it.
Jmeo
Jaime
Massachusetts
2025 Ruby Red F250, 2020 Shelby GT500
Firefighter
dolsen
KY
2022 Rapid Red 701A
It worked like a charm for me.
I’m sorry, what I meant was, did you use the -BB or -HB part number? I’m pretty sure you MUST use the -HB in a raptor…
Victorbaars
Victor
Denver
2023 F150 Raptor
Hope the frf folks will forgive me. here is the screenshot from the thread in the forum, and it seems that everyone is using the same set up.
Ford F-150 2021+ F-150 FORScan List / Database / Spreadsheet IMG_4377
