thomhunt
Minnesota
'22 F-150, '96 F-150, '13 Fusion
A - Its just me having a job that allows me to spend all day with these trucks and Ford Products. Plus I have a 2021 STX that is now a lariat. I have done everything you can imagine. I did the 8" to 12" upgrade, I even made it passive entry with push to start, Fixed DSS LED headlamps(Fully Functioning) upgrading to the Adaptive DSS LED soon(Waiting on the height sensors), Wireless charging, rain sensing wipers, 360 Cam, Digital Cluster, Rear Brake assist, Bliss, Power Fold mirrors, Will be adding Adaptive cruise with the hopes of getting Blue Cruise added also. Ive aded the auto dim rear view and side view. Will be adding B&O system and power running boards. I would have added power tailgate but it requires new tailgate. That will be last If I do it.
B - Your Apim is identical to the ones being shipped now. I can confirm this to be true. THe software build 21146 is limited to 21 trucks and 21223 is 21.5 trucks. The modules are different starting in July. The Apim is not one of those that is different though. I have confirmed I can install the 21.5 software on a APIM from early builds.
I believe the blue cruise will be sent out but I do want everyone that has not had any updates to please heed my warning to go get the dealer to update your truck ASAP. A lot of these updates that are rolling out have a prerequisite of the previous updates being installed.
The best thing you can do is get your truck fully updated now. There were MANY updates for early build trucks for modules that I believe to be not OTA capable.
These updates are very clear for the dealer in FDRS> There is a tab after they hook up that will list all the modules that need to be updated. It is clear for them. The IDS way required them to go into every module and see if an update was available.
Very nice, awesome that you were able to add all that on!
Any idea what it would take to add a heated steering wheel to a 22 501a? I have one on order and I think that's about the only thing I might miss, other than the dynamic LED projectors. It's unfortunate that the button for the steering wheel heat isn't on the steering wheel itself, as I imagine that throws a wrench in things.
yes. You need a new hvac module and a new module in the column.
You would need to wire it and some programming
also depends on if you have evasive steering. I don’t think lariats have it but I can’t say for sure
I am working on a harness to add active Dss headlamps also
thomhunt
Minnesota
Thanks for the info! Maybe something I'll take on once it's easier to find reasonably priced modules, so good to know. I'm just thrilled to be on track to get the truck in 2 months vs the 6 months as I expected.
Jeff1024
Louisville, KY
2022 F150
Question on adding the transmission temp to the 12in display. Is it possible to add the trans temp but not add the engine temp? I have my 2015 setup this way, but in the 2021+ programming spreadsheet I only saw a line item to add both.
Thanks!
C. Mays
22 F-150 Lariat; 25 Subaru Forester Sport
Project Management
Anyone found out how to disable the startup chime? Auto start stop for the 2022 changed as well, Forscan doesn’t pick up the PSCM. Anyone else?
tonesto7
Anthony
IT Admin | Software Developer
My 502a has evasive steering but not adaptive steering.
I’m basically optioned like a platinum minus the fancy seats, trim, and adaptive steering.
Snippy
Well, one step closer. I can now look at the hitch view and bed camera in motion.
Unfortunately, I haven’t figured out how to get the side view rear cam to work. I have added the bed camera tile on the side view, but no image there. Maybe it’s one of the IPMA changes that @Jesse-Infotainment had mentioned earlier. Not sure yet if it’s an APIM or IPMA issue.
The video is there obviously, as seen on full screen, but something has to format it to the side view. Maybe a trigger command. There is a bed view soft button there as well, but it doesn’t do anything but beep.
See photos, I can press the camera button and it goes first to hitch view, press again and it goes to bed view while going down the road at any speed. I had too many other chores to do today to spend anymore time on it.
Do you mind sharing the values you changed to see the camera in motion? Thanks!
sbi
Upstate SC
Anyone else have changes you made with forscan return to the default factory settings? I did the reverse brake assist changes months ago and last night backing into my garage it slammed on the brakes. I turned it off in the settings but the warning now pops up every time I go into reverse. I’m going to change it back but wondering if anyone else had this happen?
Yup. Had Lincoln Style mirrors, today I opened the driver's door and the mirrors unfolded. Yesterday it was fine, today it is not.
dbagdbag
Rockies
2021 Supra, 2021 F-150
Anyone know what I'm doing wrong ?
Converted my 35x12.5R18 tires (34.5" dia) into the following because there is no direct conversion:
Ford F-150 2021+ F-150 FORScan List / Database / Spreadsheet 1641171894066
Which puts out the following hex code/numbers to change in forscan:
Set BCM line 726-15-01 to the following:xxxx xxxx 0Axx
Set BCM line 726-15-02 to the following:66xx xxxx xxxx
Wrote the code successfully and then ran the PCM relearn to get rid of the codes (P160A & U0131), but the relearn never completes. It just says it has been interrupted at about 2%. Not sure what to do. Any issues driving the truck with these codes ?
Ford F-150 2021+ F-150 FORScan List / Database / Spreadsheet 1641172063320
Canadianeh!
Marco
Ontario
2021 f150 lariat
What did you have to do in forscan to get this to work
Zyvin
SC
2021 F150 Crew, FX4, Lariat
Canadian,
I have yet to go back and find out which ones actually enabled. I changed several values but some are relating to trying to get the side card view working, but below are the changes that I have made. My plan is to go back and take one away one by one until I know specifically which ones do what.
These are what I assume are allowing the at speed views to work (at any speed I can hit the camera button and see a bed view or hitch view and it splits the screen with the overhead 360 view).
7D0-01-04 = xxxx-FCxx-xxxx Originally = 01 in those spaces
706-02-02 = xxxF-CExx-xxxx Originally = 0, 4, C
Things I have changed, but not sure if they affect it at all (yet):
706-01-01 = xxxx-Axxx-xExx Originally = 8 and C
7D0-01-02 = Axxx-xxxx-xxxx Originally = 2
Granted the values that I pulled from a newer build do not seem to have FX4 or rock crawl mode, so you may see values in which F is more applicable than C etc. when you read the description on the spreadsheet. I haven't had much time to play with it since making these changes, but hopefully in the next week I can narrow it down. I am still trying to get the side-view to work(as the card is there but I cannot get the image to show up on that side of the screen), and trying to find a way to disable the "auto air refresh" on the A/C system.
M.R.F.O.R.D.
You need to use the new updated version. You need version 2.3.44
dbagdbag
Rockies
Try removing the vehicle profile (vehicle-->profiles) and reconnect
I deleted the profile, reconnected the obdlink ex and still have the same issue, it just keeps saying interrupted when trying the pcm relearn
