TSB 24-2126 Air Conditioning
wbarrett
LaGrange,GA
2023 King Ranch 4x4 Powerboost
Dropped off my 2023 King Ranch 4x4 Powerboost to get the air conditioning PCM and HVAC firmware modules updated per this TSB.
TECHNICAL SERVICE BULLETIN
Air Conditioning (A/C) Inoperative, Lack Of Air Flow, Blows Warm, And/Or Evidence Of Evaporator Freezing
24-2126
26 April 2024​
This bulletin supersedes 24-2093. Reason for update: address the revised software and include affected 3.5L PowerBoost vehicles
Model:
Ford
2021-2022 F-150
non-Lightning
2023 F-150non-3.3L
non-Lightning
Markets: North American markets only
Issue: Some 2021-2023 F-150 vehicles equipped with a gasoline, hybrid or flex fuel engine (non-Lightning) except 2023 F-150 with 3.3L may exhibit inoperative A/C, lack of air flow, blows warm, and/or evidence of the evaporator freezing. This may be due to the software level of the PCM and HVACmodule. To correct this condition, follow the Service Procedure to reprogram the PCMand HVAC module to the latest software level via the FDRS.
Dealer said I was second to have this done so no word on effectiveness. Here in Georgia I couldn’t face another summer with the AC evaporator freezing up after 1.5 hours of use any more.
Will update if and how well this TSB turns out.
Suns_PSD
The Dude
CTX
2021 F150 4x4 Limited
Sales
Mine does this as well.
m_bt54
Bryan
Massachusetts
IT Director
Nice. Good to see this is applicable to the PBs. I thought I had read it didn’t and would be coming in the future
wbarrett
LaGrange,GA
So far so good. I picked my PB up today and it made it over a hour in high humidity without a freeze up. (Knock on wood).
Observations:
1. The PCM update resets your middle 2 of 4 gauges to default if you had changed them from default.
2. The transmission loses all your driving style learnings. It downshifts as harshly as it did when new for me now.
3. The 1-3 shift bypass is fixed and now upshifts 1, 2, 3 etc properly without the jump past 2. I tested this in both Normal and Eco modes.
mistermoon
Acworth, GA
2022 F150 XLT Supercrew 4x4 PB
Had mine done last week. Too early to tell if it's working.
I've not noticed any difference in shifting, but have not been watching it either. The 1-3 shift never bothered me anyway. Mine always shifts 1-2 when towing my camper, 1-3 without. Now I've got something to look for.
Jerome10
North Idaho
This only has to do with AC issues correct? Not the (seemingly normal) function in winter where even on low fan and temps at 63 or 64F the truck blows very hot air on your feet.
I've not had any issue with my AC thankfully. But one question.... Where I live in Idaho it gets quite hot in summer (days in 90s and possibly over 100) but it is extremely dry. Have people seen this issue in this type of dry-heat climate or are people seeing this like in the South and Midwest with the much higher humidities?
Cjones1999
Colton
Fyffe, AL
2023 Ford F-150 2.7L Ecoboost
Just had my 2023 F150 2.7 done yesterday. Drove it for around a hour on and off. Still seemed to have less airflow on max ac than when I first start the truck. Prior to the reprogram I had no airflow after about twenty-thirty minutes of running the AC. Now after the same amount of run time I still feel some airflow yet it isn’t as strong as it is when I first start the truck. Anyone else still noticing a lack of airflow even after the reprogram?
23PB&Me
Oregon
23 PB Lariat
I had an instance last week where I remote started the truck and when we got to it the air was on full blast hot. The temp gauges said the correct set point, we set it to max AC and low but it still blew hot air. Killed the truck, open/closed the door, turned it back on and it started working. I wonder if this TSB is related to that or if it was a remote start glitch. This definitely wasn’t “warm” air, it was full blast hot air. Cab was so hot the wife got out and waited in the sun and heat outside while I tried to figure it out.
Grettman
Michael
2023 F150 Tremor
24-2126
26 April 2024​
Model:
Ford
2021-2022 F-150
non-Lightning
2023 F-150non-3.3L
non-Lightning
Hi, did this work out for you okay? I have this issue. I really don't want to take it to the dealer -- especially if this isn't the fix.
wbarrett
LaGrange,GA
Yes it has. Hotter and more humid than ever before in Georgia and I have not had an issue.
Grettman
Michael
2023 F150 Tremor
Thank you! Do you know what the underlying issue is? I understand it is a software fix but what is the software update fixing? I haven't been able to find an answer to this.
Anyway, I guess I will proceed with opening a call with the dealership.
wbarrett
LaGrange,GA
No idea. I suspect that it changes how the temperature sensor is read and interpreted
