Trying to purchase a connector
Spiffy
Usa
2022 platinum powerboost
I broke a release tab on a connector. C242C. I located the connector number in alldata.
It says it's not available. I just need the housing.
There is a number under harness. Does that mean I need to buy the harness?
There is another connector right by it C242B that has a pigtail available. (Super expensive) the cases look identical.
Ford F-150 Trying to purchase a connector 17376617118397412784576188641951
Ford F-150 Trying to purchase a connector 17376619836116800920008542194655
roadPilot
SE Michigan
I would be surprised if it could be ordered separately.
Ford F-150 Trying to purchase a connector 1737662729754-90
Spiffy
Usa
In the screen shot where it just showes a harness number does that mean the harness needs replaced? That's a big harness $$$$.
I could try to plug in the 242b into the 242c plug and see if it fits then buy the pigtail version.
I know the connectors are supposed to be different so you don't get them mixed up but how the connects come off the harness it's impossible to mix up. Too tight.
The connector itself is likely available for a few $. You'd have to depin/repin which some can find difficult. You will not find ford telling you what the part number and manufacturer is. Also there's 'keying' on the connectors and you need to make sure it matches.
antho
Anthony
Houston, Texas
2024 Raptor 37
Exactly. Its likely a TE connectivity 20 cavity connector.
Kanuck
Winnipeg, Manitoba
Retired Electrician
There are a bunch of You Tube videos on a temp fix with zip ties and other methods. Until you get the new part.
Spiffy
Usa
The connector holds tight. I have to get in with a pic to pull the broken tab back. For me not a problem.
The problem is I have to take it in for a issue with ipma calibration and dealer might have to swap it.
If they can't get it off they most likely will require a new connector and possibly not warranty it.
Pin/depin is no problem for me . I do it most days on pins much smaller on avionics navigation radios. Some connectors i build or modify have nearly 80 pins.
I just have to repair this connector.
Spiffy
Usa
Worst case . I found a ipma for 150.00 that has the connectors. Wrong ipma thoe.
The pig tale version from ford is over 100.00 and the keyway is slightly off center. I would have to dremel off the keyway.
That one from digikey looks close but it has two keyways and best I can tell is friction fit. Thanks for all the advice so far.
Spiffy
Usa
Ha ha. Not a chance!
I removed the ipma
Here is the photo of the connector. It's the middle black one. I can get the left Grey in a pigtail version. 120.00 Both same size but the keyway at the top are in different locations. Not a big deal. I'm sure I can remove the key.
The ebay ipma with the connectors got sold.
There are 8 others, most from resellers. I have texted them to see if they by chance have the connector. Most times when stripping salvaged the wires just get cut.
Ford F-150 Trying to purchase a connector 17376824053256261218006180716506
{tpc}
Anthony
Berkley, MI
Contact TE and see if they will send you a sample?
JScaro
Georgia
2021 Ford F150 Lariat 501.5A
Beer Drinker
I removed the ipma
Maybe this one?
https://www.mouser.com/ProductDetail/TE-Connectivity-AMP/2288276-1?qs=iR2ablhfrmFQ0tikRKv%2B8w==
Ford F-150 Trying to purchase a connector 1737724052227-5m
tmark
Thomas
2021 F150 King Ranch powerboost
It has been a good while, but in my job we had a "pin pusher" tool that would release the locking tab on the pin and allow you to push it out. Easy Peasy. That was round pins only, and that style may be obsolete now.
