thinking of battery replacement out of pocket
stlgrym3
SoCal
2023 F150 PB Lariat
i've been having issues with battery constantly in saver mode when the truck is not driven for 2-3 days. i've posted threads in the other sub-forums about this. instead of a battery tender, i'm leaning toward a better battery replacement instead. yes, it will be out of my own pocket since dealer won't do that because their diagnostic tool never detects any issues with my battery. those of you have replaced battery on your Powerboost, which brand and model do you recommend? our Powerboost only accepts H7 AGM batteries, correct? thanks.
mdn14
NE, OH
Structural Engineer
stlgrym3
SoCal
2023 F150 PB Lariat
^^^ thanks. for those of you replaced the batteries, does that resolve the battery saver mode issue? also, when replacing a battery, do you lose your bluethooth settings and connectivity to FordPass?
m_bt54
Bryan
Massachusetts
IT Director
I have one of these Walmart batteries charged up in my back seat as I try to decide if I want to stick with my factory battery a little longer. I had some issues and had to charge mine up the other day but of course since I bought the replacement I have had no issues. I’ll keep it the full two week return period before I decide.
if you go this route, note that the listing says 800 cca and the picture shows 850. It is indeed, 800 (at least at my local stores in MA).
Micho523
Jaime
Atlantic Beach FL
2023 Lariat 502a
Upgrading the battery resolved all of my weird little issues, no settings were lost. Be sure you reset your BMS after the swap.
m_bt54
Bryan
Massachusetts
IT Director
how do you reset the BMS? thanks.
Turn the truck on to accessory. Flash the headlights 5 times. Then press the brake pedal 3 times. The battery icon will flash 3 times.
Micho523
Jaime
Atlantic Beach FL
2023 Lariat 502a
Can also be done easily with Forscan if you've got that. Procedure attached.
GrandpaD
Dennis
Hampton Roads, Virginia
'24 Lariat PB FX4 502A 5.5 Space White
I replaced the OEM with the Everstart Platinum H7 and all the "shutting down", etc. disappeared. I didn't lose any settings when the new battery was installed.
Brad34
Minnesota
2021 F150 XLT 302a 3.5 Ecoboost Screw
The only setting I lost when I changed my battery was the instrument cluster layout. I had to arrange the gauges and "My View" back to the way I liked. All of the Bluetooth settings and radio presets were preserved.
stlgrym3
SoCal
2023 F150 PB Lariat
i want to buy the Forscan kit. are they being sold on amazon? what's included in the entire kid? a link would be great. i've used Ecutek with my Subaru BRZ before for tuning, Forscan should be similar right, one end plug into OBDII, the other to USB on your laptop?
just took a look on Amazon, there are lots of different variety of the Forscan tools, any specific one for 2023 powerboost F150?
https://www.amazon.com/ELMconfig-Au...1-2-spons&sp_csd=d2lkZ2V0TmFtZT1zcF9hdGY&th=1
Micho523
Jaime
Atlantic Beach FL
2023 Lariat 502a
https://www.amazon.com/ELMconfig-Automatic-Transform-Professional-Diagnostic/dp/B08HRR1QMH/ref=sr_1_2_sspa?crid=3FN1FEGNT4B4D&keywords=forscan+f150&qid=1706718749&s=automotive&sprefix=forscan,automotive,253&sr=1-2-spons&sp_csd=d2lkZ2V0TmFtZT1zcF9hdGY&th=1
This is the only adapter I recommend, and is one recommended by Forscan themselves:
https://a.co/d/7DRyldJ
As far as the "kit" the adapter you buy on Amazon is only the adapter. You will need to download the software from here:
https://forscan.org/
To make any changes, you will need an extended license. They offer free two month trials and a one year paid license for $12. You can get unlimited trials, but the development team deserves the $12 in my opinion.
You'll want to familiarize yourself with the forscan spreadsheet, which is a pinned link here.
https://bit.ly/3cJnYMS
oncechance
Indiana
Not to muddy the waters, but I believe the below is what is recommended:
https://www.amazon.com/gp/product/B081VQVD3F/ref=ppx_yo_dt_b_asin_title_o08_s00?ie=UTF8&psc=1
Micho523
Jaime
Atlantic Beach FL
2023 Lariat 502a
