Swapping headlights from reflector to projector LED headlights?
Stefanolimotta
stefano
21 f150
Construction
This is for wheel base, really don’t think it will make a difference.
The headlights move with the steering wheel when going above 20mph.
You may need to adjust the headlights to get the proper beam.
On the LED projector headlight, the top is always on but never changes brightness. The lower led does the low and high beam.
how do I do that? I didn’t know you can do that. Also when I turn the high beams on the low beams turn off instead of staying on. I’m pretty sure they don’t move though.
What codes is the HCM throwing? Did you calibrate it?
JScaro
Georgia
2021 Ford F150 Lariat 501.5A
Beer Drinker
i don’t think you can calibrate the HCM unless all the sensors are hook up/
Stefanolimotta
stefano
21 f150
Construction
I can’t remember off the top of my head but there a few some thing about an open ground witch I saw on it was connected in the engine bay. And some about the head light motors.
Stefanolimotta
stefano
21 f150
Construction
Going to need a long Philips screwdriver and follow this.
https://www.f150gen14.com/forum/threads/headlight-correction-following-level.5360/post-119481
Your headlights must not be wired right if the top bulbs go out with your high beam.
Well before I used forscan to make the hyper flash go away they did work right witch was super weird but if they aren’t wires right I need a new harness no? It’s plug and play and every thing only fits one way and I put the plugs on the right way because there labeled driver and passenger side
